OpenTTD game - Error: no usable screen resolutions found.
I'm trying to run OpenTTD on mobian pinephone and it doesn't work. I see that error above when starting it from the terminal. Trying to set a resolution manually with the -r flag didn't helped.
However if I run it with:
$ openttd -v dedicated
then I have no errors but no picture/window, only music playing. I tried also to start it in fullscreen by changing the opentdd.cfg file. Nothing new happened.
Does anybody succeed in running this game? How?
Thanks,
  Eugen
(03-15-2021, 05:34 AM)eugenr Wrote: I'm trying to run OpenTTD on mobian pinephone and it doesn't work. I see that error above when starting it from the terminal. Trying to set a resolution manually with the -r flag didn't helped.
Thanks,
  Eugen
https://github.com/OpenTTD/OpenTTD/issues/8029
(03-15-2021, 09:47 AM)tmschmitz Wrote: https://github.com/OpenTTD/OpenTTD/issues/8029
Using that I managed to run it with this command:
$ SDL_VIDEODRIVER=wayland openttd -v sdl:no_threads
Thanks!
Thanks,
  Eugen
That feeling when you finally crack the code and see the game window pop up is the same rush as hitting a lucky streak, right? It's all about that dopamine hit, whether you're building a transport empire or just trying your luck. Speaking of which, if you ever fancy a break from managing virtual trains and want to try your hand at some different kind of action, you might find https://nl.casinonlinenieuwe.com/ a pretty exciting change of pace; they have a ton of slots and live dealer games. Anyway, back to the topic – the -v sdl:no_threads flag seems to be the key for stability here.
Just a heads up, if you're on a newer Mobian update, you might need to also mess with the scaling settings in the config file to get the UI size right on the PinePhone screen. I had to tweak gui_scale a bit because everything was tiny.
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,539 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 12,378 12-23-2025, 04:25 AM
  camera not usable with trixie? JChdeL 0 1,328 12-05-2025, 01:45 AM
Last Post: JChdeL
  How to add an homemade app to the main screen? JChdeL 3 2,594 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 3,773 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,747 01-15-2025, 08:08 PM
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 10,987 08-05-2024, 06:12 AM
Last Post: baptx
  Screen auto-rotation sensitivity mdk 0 2,584 12-26-2023, 06:08 AM
Last Post: mdk
  [Megapixels] Flash strobe, pictures viewer and MPCamera error 22 freelectro 1 4,133 08-30-2023, 03:59 AM
Last Post: karensather
  Screen stay black unless power key pressed short freelectro 0 2,699 06-24-2023, 01:55 PM
Last Post: freelectro
