PinePhone sensors - Gyroscope power
So I got the proximity / light sensor working in my Zig OS Smile  Although the sensor seems to be always powered on, which kinda makes sense, but I somehow expected a GPIO pin for switching it off.
Now I am looking at the gyroscope, wow it looks complicated Smile and I am kinda glad to see the secondary I2C fusion? lines are not connected.
But here again it seems to be always powered on? (based on schematic), and I recall from my early iOS days, that gyroscopes can waste some power when always on.  Did I miss something?
The PinePhone hardware is not optimized for power consumption at all. I guess the gyroscope is the least of your worries there.
(11-27-2025, 03:45 PM)Kevin Kofler Wrote: The PinePhone hardware is not optimized for power consumption at all. I guess the gyroscope is the least of your worries there.
Thanks for the honest answer!  I'm hoping at some point I'll be able to use the RSB bus to monitor power usage, if that is supported?  Are there any power hungry parts I should be watching out for please?
I did manage to get the idle temperature down to 42C, so I hope that will reflect in less power usage Smile  Although I think I'll need a 2nd core fired up soon, if I can work out how.
Whatever else people say about the PinePhone, I think it is a great learning tool for systems programming!
Well I got the gyroscope working Smile and the strange thing is, this chip actually has a low power sleep mode!
I had another look at RSB to the PMIC, but cant figure out how to read power use when no battery.  I thought the Coulomb counter might have been it, but reports only 0.
I tried my cheap USB tester gadget, but doesnt seem sensitive enough for a running device vs charging.  It shows 3mAh which seems far too low, although no WiFi or cellular powered at the moment...
  Pinephone software Csanderson0313 3 1,390 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 84,606 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 24,703 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 8,224 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 8,211 02-28-2026, 05:49 PM
Last Post: baptx
  Power up a 2nd core? WhiteHexagon 1 1,410 01-03-2026, 02:24 AM
Last Post: WhiteHexagon
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,520 12-04-2025, 08:07 AM
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,981 12-01-2025, 10:25 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,055 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,105 10-21-2025, 12:12 PM
Last Post: Richy_T
