Pinephone visibly losing power while plugged in
I have a pinephone community edition running mobian.
Most of the time it sits, off, because we're not allowed to have phones at work, and I don't have a lot of people to talk to (when I'm at home, I use my desktop, anyway).
I've noticed lately that plugged into my computer, it seems to lose about 1% power every 3 minutes or so.
Plugged into the power outlet, however, it seems to lose about 1% power every 3 minutes or so.
The only way I seem able to charge it now is to turn it off and plug it in.
I've set it as power-saving as I can figure out. It sits in suspend mode with the screen off.
I have wifi, bluetooth and cellular on.
The battery icon shows the thunderbolt, and I get the message that its charging... but it's draining faster than it's charging.
There's nothing wrong with the cable; I've used it to connect an android tablet that charges just fine.
I've flipped the usb-c end in case there's a frontwards/backwards way to insert it (hey, I'm desperate).
It does not get hot. Plugged in or not, it only gets *slightly* warm.
Can anyone help me with this? I haven't seen this specific problem anywhere in the forums. I love my pinephone and don't want to give it up.
(05-22-2025, 08:18 PM)Hiraghm Wrote: Can anyone help me with this? I haven't seen this specific problem anywhere in the forums. I love my pinephone and don't want to give it up.
Hello!
I suggest getting a better wall charger.
Related points to keep in mind
The Phone will draw 3-5 Watts just sitting.
Computer USB ports can typically have a .1amp to .5amp at 5V is max 2.5 Watts. This is why you are seeing a battery drain.
You will need at least a 5 Watts wall charger. Most little wall chargers that come with EVERYTHING are 5 to 8 watts. Buy a QC3.0 or PD65W charger.
Here is a link[1] to a good 20 Watt charger I use.
The phone also has smarts to talk with the charger and set the current draw. This to help battery life. In Arch Linux, I use a package called powersupply[2] it shows me what current the charger has and what PD version it is using. It also shows me what wattage the phone is using.
To your Android tablet statement:
Android has INSANE power management and can "charge" slowly with a few watts. All modern Android devices will tell you "Charging Slowly" "Charging" "Charging fast" "Turbo Charging"
[1] https://ameridroid.com/products/usb-a-us...dapter-20w
[2] https://gitlab.com/MartijnBraam/powersupply
(05-22-2025, 08:18 PM)Hiraghm Wrote: we're not allowed to have phones at work
Sounds like an unpleasant place to work at! There better ought to be a really good reason for that or I would be looking for a friendlier place to work at immediately.
As for the charger, I use a 12W (2.4A) USB A charger (adapter brick style) from a little-known brand (Nedis WCHAU242AWT), which can be had here for less than 9€.
I just had a charging issue with my PinePhone (on Mobian 12 stable), it was charging very slowly and with the app Powersupply I was able to see that it was charging at less than 1W. Restarting the phone fixed the issue and it was charging normally at around 4 or 5W.
@tophneal @evilbunny I saw the related thread https://forum.pine64.org/showthread.php?...509&page=2 is closed but it would be useful if a moderator can reopen it to add a warning for people reading it. Here is the message I wanted to post:
It is a bad idea to use ">" in this case, better use ">>" otherwise it could overwrite content you already have in the file.
You can do it with sudo also like this:
sudo sh -c 'echo "blacklist anx7688" > /etc/modprobe.d/blacklist.conf'
Or use an editor with sudo:
sudo vi /etc/modprobe.d/blacklist.conf
I also read about blacklisting anx7688 on https://www.reddit.com/r/pinephone/comme...d_for_the/ but it did not work in my case with the PinePhone on Mobian 12 stable.
Sometimes rebooting fixed the slow charging issue but not every time, I checked with the app Powersupply.
I tested with the USB A to C cable delivered with the phone.
If someone has another solution to force charging faster, it would be nice to share.
Update: Making the phone boot automatically by plugging in the charger fixed the issue again but I don't know if it will work every time. In the app Powersupply, I can see the current limit is now 1.5A instead of 0.5A. When the charging percentage reaches around 99%, I noticed it charges more slowly (below 1W instead of 4 or 5W) until it stops at 100%, even if it still shows 1.5A.
I've added a post linking to yours above for anyone that goes to that thread.
(10-07-2025, 07:30 AM)baptx Wrote: @tophneal @evilbunny I saw the related thread https://forum.pine64.org/showthread.php?...509&page=2 is closed but it would be useful if a moderator can reopen it to add a warning for people reading it. Here is the message I wanted to post:
Update: Making the phone boot automatically by plugging in the charger fixed the issue again but I don't know if it will work every time. In the app Powersupply, I can see the current limit is now 1.5A instead of 0.5A. When the charging percentage reaches around 99%, I noticed it charges more slowly (below 1W instead of 4 or 5W) until it stops at 100%, even if it still shows 1.5A. Powersupply shows 1.5A current when it works properly.
I also read about blacklisting anx7688 on https://www.reddit.com/r/pinephone/comme...d_for_the/ drive mad but it did not work in my case with the PinePhone on Mobian 12 stable.
What more information would you like to know?
That's a really frustrating issue! It sounds like you've tried all the basic troubleshooting steps. Have you considered looking into the battery health diagnostics within Mobian? Maybe there's a process running in the background that's consuming power despite the suspend mode. Thinking about it, that constant drain even while "charging" suggests the charging circuit might be struggling. Is there a way to measure the actual charging current? Perhaps the voltage slope isn't high enough to overcome the drain, even with the charging indicator showing.
I noticed the workaround I mentioned "Making the phone boot automatically by plugging in the charger" is only needed for the red USB cable that was delivered with the PinePhone that is not working anyway for data transfers because according to Pine64, it is a charging power cable, not a data cable (https://forum.pine64.org/showthread.php?...#pid126108).
By using another USB cable, the phone charged fast without needing to reboot.
After 2 years configuring the PinePhone to fix issues like https://gitlab.com/Alaraajavamma/fastvid...rk_items/7, https://github.com/the-modem-distro/pine...issues/259 and https://salsa.debian.org/Mobian-team/dev...rk_items/7, I am now daily driving it since this month with Mobian trixie and Phosh. My previous Jolla smartphone from 2013 did not have Sailfish OS updates anymore and was unusable on many websites.
  PinePhone Game Thread PixelPaintbrush 32 90,518 Yesterday, 12:51 AM
Last Post: NorrisFByrd
  Pinephone software Csanderson0313 3 2,356 07-10-2026, 02:21 PM
  How can I record video on a Pinephone? kk22 23 27,919 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 9,556 02-28-2026, 05:49 PM
Last Post: baptx
  Power up a 2nd core? WhiteHexagon 1 1,905 01-03-2026, 02:24 AM
Last Post: WhiteHexagon
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,973 12-04-2025, 08:07 AM
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,759 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 3,366 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,791 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 9,322 10-21-2025, 12:12 PM
Last Post: Richy_T
