Rock64 - not booting after Armbian update
I have Rock64 Ver.2 - 1gb model.
Was working fine with Armbian 24.5.0-trunk.211_Rock64_bookworm_current_6.6.21 - boot from micro SD card
On SSH, I updated to latest version Armbian_25.2.1_Rock64_bookworm_current_6.12.13. Now it does not boot from micro SD card.
I had another micro sd card. I flashed new Armbian_25.2.1_Rock64_bookworm_current_6.12.13 - does not boot.
I had another micro sd card. I flashed OLD Armbian 24.5.0-trunk.211_Rock64_bookworm_current_6.6.21 - it boots. Then updated to latest Armbian & does not boot anymore.
Looks like some " Flashing_u-boot_to_SPI_Flash " - problem.
Please help.
Thanks in advanced
I'll never understand why Linux feels that it's appropriate to modify your firmware during an upgrade. Does x86 Linux reflash your BIOS when upgrading?
In any case; if you boot from the one which still boots, use it to erase your SPI ROM and try booting the newer one.
:wq
I flashed with newest uboot but same thing - no boot.
https://github.com/ayufan-rock64/linux-m...-g4e6f4563
Did you flash it to the SPI ROM? If not, have you erased the SPI ROM?
:wq
First I flashed this to erase it :
u-boot-erase-spi-rock64.img.xz
then
I flashed with to write it:
u-boot-flash-spi-rock64.img.xz
after flashing - white led flashes continuously.
removed power. removed micro sd card & put newly burned Armbian_25.2.1 micro sd card - does not boot
Old Armbian boots as well as Dietpi boots
Does U-Boot say anything different between working and not working?
I wonder if something in /boot changed in Armbian.
:wq
Ah ha, I think you have used wrong image, rock64 is
probably for rk3328, I might be wrong
And this is why, unless you are REALLY sure, it is not so good to flash SPI
There is a jumper connection to short SPI clock, so not such a big deal
opps, I see that maybe you really have a rock64, for some reason I thought you had rockPro
anyway, I think the clock signal is on pin7 so jumper 7->9 for a few seconds when booting (40 pin connector)
Lightbulb
Hello, I had a similar problem - unbootable Rock64 after kernel upgrade from 6.6.x to 6.12.x (error: Wrong Ramdisk Image Format).
You can look in this armbian forum thread djurny found a solution, that works for me. Maybe it will help.
Add to armbianEnv.txt
# new load addresses
fdt_addr_r=0x01f00000
kernel_addr_r=0x02000000
ramdisk_addr_r=0x04400000
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 368 01-28-2026, 04:04 AM
Last Post: alicesphere
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 11 16,729 12-06-2025, 01:32 PM
  Xen hypervisor on Rock64 tumbleweed 6 10,493 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 2,631 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,757 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 3,933 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 77,212 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 103,761 09-01-2024, 06:05 AM
  How to update/compile Debian 12.5? Wizardknight 3 4,163 03-29-2024, 05:01 AM
Last Post: gedas07
  Rock64 v2 - did not work song / audio sqw200zu 2 5,269 03-14-2024, 03:09 AM
