What's a good image to use now? [tutorial help as well]
#31
It seems to have found the previous attempts, this is where it seems to go wrong,
at the release signature
>>>> Mounting target filesystem
+ '[' -z '' ']'
+ mkdir -p /home/d/pinebook-pro-debian-installer/sysimage
+ sudo mount /dev/sda6 /home/d/pinebook-pro-debian-installer/sysimage
+ sudo mkdir -p /home/d/pinebook-pro-debian-installer/sysimage/boot
+ sudo mount /dev/sda5 /home/d/pinebook-pro-debian-installer/sysimage/boot
+ sudo mkdir -p /home/d/pinebook-pro-debian-installer/sysimage/boot/efi
+ sudo mount /dev/sda4 /home/d/pinebook-pro-debian-installer/sysimage/boot/efi
+ do_debootstrap
+ printf '\n\n>>>> Installing base system\n\n'
+ '[' '!' -e debootstrap-arm64.tar.gz ']'
+ do_real_debootstrap
+ sudo debootstrap --arch=arm64 --include ca-certificates,console-setup,cryptsetup-initramfs,initramfs-tools,locales,keyboard-configuration,network-manager,sudo,u-boot-menu,gnupg,plymouth,plymouth-themes bullseye /home/d/pinebook-pro-debian-installer/sysimage
I: Retrieving InRelease
I: Checking Release signature
E: Release signed by unknown key (key id 605C66F00D6C9793)
+ do_umount
+ printf '\n\n>>>> umount\n\n'
>>>> umount
+ for i in boot/efi boot dev proc sys
+ sudo umount /home/d/pinebook-pro-debian-installer/sysimage/boot/efi
+ true
+ true
+ sudo umount /home/d/pinebook-pro-debian-installer/sysimage/dev
umount: /home/d/pinebook-pro-debian-installer/sysimage/dev: mountpoint not found
+ sudo umount /home/d/pinebook-pro-debian-installer/sysimage/proc
umount: /home/d/pinebook-pro-debian-installer/sysimage/proc: mountpoint not found
+ sudo umount /home/d/pinebook-pro-debian-installer/sysimage/sys
umount: /home/d/pinebook-pro-debian-installer/sysimage/sys: mountpoint not found
+ true
+ '[' '!' -z '' ']'
What you use is not my modified installer but Daniel Thompson's original installer. His does not work anymore.
Do a "git log" and compare the commit messages with the commit messages from my repository https://github.com/schaecsn/pinebook-pro...ts/master/. I expect them to be different.
You are right, I didn't realize that the Danial Thompson installer was on
the sd card, and I tried again ... and failed
Probably because of sd boot, your git is on emmc (which is where I started at)
---- in section >>>>> installing base system
E: no such script: /usr/share/debbootstrap/scripts/bookworm
so I copied this and debian-common to sd .....but then
release signed by unkown key ..... f8d2585b8783g481
which probably comes back to Daniel Thompson
I'm guessing I should install git on sd card after renaming original?
Oh, I did not know that debootstrap has config files for every Debian version. The debootstrap from Mrfix's Debian 9 is apparently not aware of Debian Bookworm. Copying over the config files is a hack and I do not know in what follow up issue you may run. If I recall, you have Manjaro on emmc. That should be more recent than Mrfix's Debian 9. I recommend you using that as a starting point.
You don't need to backup Daniel Thomspon's installer. You can clone mine into another directory.
Here is my installation from a Manjaro micro SD (last updated March 2024) on an usb thumb drive (I needed to change the swapfile size from 2GB to 1 MB in the installer as my whole usb thumb drive is 2 GB in total).
manjaro:~$ git clone https://github.com/schaecsn/pinebook-pro-debian-installer pinebook-pro-debian-installer-new Cloning into 'pinebook-pro-debian-installer-new'... remote: Enumerating objects: 267, done. remote: Counting objects: 100% (35/35), done. remote: Compressing objects: 100% (24/24), done. remote: Total 267 (delta 15), reused 25 (delta 9), pack-reused 232 (from 1) Receiving objects: 100% (267/267), 66.96 KiB | 357.00 KiB/s, done. Resolving deltas: 100% (132/132), done. manjaro:~$ cd pinebook-pro-debian-installer-new/ manjaro:~/pinebook-pro-debian-installer-new$ ./install-debian BLKDEV=/dev/sda >>>> Preparing to install Submodule 'ap6256-firmware' (https://gitlab.manjaro.org/manjaro-arm/packages/community/ap6256-firmware) registered for path 'ap6256-firmware' Submodule 'bootloader' (https://github.com/mrfixit2001/updates_repo) registered for path 'bootloader' Submodule 'firmware' (https://gitlab.manjaro.org/tsys/pinebook-firmware.git) registered for path 'pinebook-firmware' Cloning into '/home/schaecsn/pinebook-pro-debian-installer-new/ap6256-firmware'... warning: redirecting to https://gitlab.manjaro.org/manjaro-arm/packages/community/ap6256-firmware.git/ Cloning into '/home/schaecsn/pinebook-pro-debian-installer-new/bootloader'... Cloning into '/home/schaecsn/pinebook-pro-debian-installer-new/pinebook-firmware'... Submodule path 'ap6256-firmware': checked out 'a30bf312b268eab42d38fab0cc3ed3177895ff5d' Submodule path 'bootloader': checked out 'c95331aecdb961afbca6e6ed73393d6abe7fdc7d' Submodule path 'pinebook-firmware': checked out '937f0d52d27d7712da6a008d35fd7c2819e2b077' [sudo] password for schaecsn: warning: dosfstools-4.2-3 is up to date -- skipping resolving dependencies... looking for conflicting packages... Packages (2) debootstrap-1.0.134-1  pigz-2.8-1 Total Download Size:  0.11 MiB Total Installed Size:  0.36 MiB :: Proceed with installation? [Y/n] :: Retrieving packages... pigz-2.8-1-aarch64              80.9 KiB  83.4 KiB/s 00:01 [################################] 100% debootstrap-1.0.134-1-any        36.5 KiB  30.9 KiB/s 00:01 [################################] 100% Total (2/2)                    117.4 KiB  83.8 KiB/s 00:01 [################################] 100% (2/2) checking keys in keyring                              [################################] 100% (2/2) checking package integrity                            [################################] 100% (2/2) loading package files                                  [################################] 100% (2/2) checking for file conflicts                            [################################] 100% (2/2) checking available disk space                          [################################] 100% :: Processing package changes... (1/2) installing debootstrap                                [################################] 100% Optional dependencies for debootstrap     gnupg: check release signatures [installed]     debian-archive-keyring: check release signatures for Debian     debian-ports-archive-keyring: check release signatures for Debian Ports     ubuntu-keyring: check release signatures for Ubuntu (2/2) installing pigz                                        [################################] 100% :: Running post-transaction hooks... (1/1) Arming ConditionNeedsUpdate... >>>> Partitioning Checking that no-one is using this disk right now ... OK Disk /dev/sda: 1.86 GiB, 1992294400 bytes, 3891200 sectors Disk model: USB Disk        Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x6d5bf375 Old situation: Device    Boot  Start    End Sectors  Size Id Type /dev/sda1  *          0 1292287 1292288  631M  0 Empty /dev/sda2          4524  23563  19040  9.3M ef EFI (FAT-12/16/32) /dev/sda3      1292288 3891199 2598912  1.2G 83 Linux >>> Script header accepted. >>> Script header accepted. >>> Script header accepted. >>> Created a new GPT disklabel (GUID: 989448C7-C35A-461A-A0E3-BA1B696820C6). /dev/sda1: Created a new partition 1 of type 'Linux reserved' and of size 8 MiB. /dev/sda2: Created a new partition 2 of type 'Linux reserved' and of size 4 MiB. /dev/sda3: Created a new partition 3 of type 'Linux reserved' and of size 4 MiB. /dev/sda4: Created a new partition 4 of type 'EFI System' and of size 200 MiB. /dev/sda5: Created a new partition 5 of type 'Linux filesystem' and of size 500 MiB. /dev/sda6: Created a new partition 6 of type 'Linux filesystem' and of size 1.2 GiB. /dev/sda7: Done. New situation: Disklabel type: gpt Disk identifier: 989448C7-C35A-461A-A0E3-BA1B696820C6 Device      Start    End Sectors  Size Type /dev/sda1      64  16383  16320    8M Linux reserved /dev/sda2    16384  24575    8192    4M Linux reserved /dev/sda3    24576  32767    8192    4M Linux reserved /dev/sda4    32768  442367  409600  200M EFI System /dev/sda5  442368 1466367 1024000  500M Linux filesystem /dev/sda6  1466368 3889151 2422784  1.2G Linux filesystem The partition table has been altered. Calling ioctl() to re-read partition table. Syncing disks. >>>> Installing Pinebook Pro boot firmware 39+1 records in 39+1 records out 163836 bytes (164 kB, 160 KiB) copied, 0.0543011 s, 3.0 MB/s 1024+0 records in 1024+0 records out 4194304 bytes (4.2 MB, 4.0 MiB) copied, 0.9898 s, 4.2 MB/s 1024+0 records in 1024+0 records out 4194304 bytes (4.2 MB, 4.0 MiB) copied, 0.521563 s, 8.0 MB/s >>>> Formatting mkfs.fat 4.2 (2021-01-31) mke2fs 1.47.0 (5-Feb-2023) Creating filesystem with 512000 1k blocks and 128016 inodes Filesystem UUID: bc929f54-d7da-4fdb-b2db-f149a463395c Superblock backups stored on blocks: 8193, 24577, 40961, 57345, 73729, 204801, 221185, 401409 Allocating group tables: done                            Writing inode tables: done                            Creating journal (8192 blocks): done Writing superblocks and filesystem accounting information: done mke2fs 1.47.0 (5-Feb-2023) Creating filesystem with 302848 4k blocks and 75840 inodes Filesystem UUID: 2770faaa-860b-4c4a-a3bb-2435cfc6f16d Superblock backups stored on blocks: 32768, 98304, 163840, 229376, 294912 Allocating group tables: done                            Writing inode tables: done                            Creating journal (8192 blocks): done Writing superblocks and filesystem accounting information: done >>>> Mounting target filesystem >>>> Installing base system I: Keyring file not available at /usr/share/keyrings/debian-archive-keyring.gpg; switching to https mirror https://deb.debian.org/debian I: Retrieving InRelease I: Retrieving Packages I: Validating Packages I: Resolving dependencies of required packages... I: Resolving dependencies of base packages... I: Checking component main on https://deb.debian.org/debian... I: Retrieving adduser 3.134 I: Validating adduser 3.134 I: Retrieving apt 2.6.1 I: Validating apt 2.6.1 I: Retrieving apt-utils 2.6.1 I: Validating apt-utils 2.6.1 I: Retrieving base-files 12.4+deb12u9 I: Validating base-files 12.4+deb12u9 I: Retrieving base-passwd 3.6.1 I: Validating base-passwd 3.6.1 I: Retrieving bash 5.2.15-2+b7 I: Validating bash 5.2.15-2+b7 ... I: Configuring initramfs-tools... I: Base system installed successfully. [sudo] password for schaecsn: >>>> Creating Swapfile 1+0 records in 1+0 records out 1048576 bytes (1.0 MB, 1.0 MiB) copied, 0.0343232 s, 30.6 MB/s Setting up swapspace version 1, size = 1020 KiB (1044480 bytes) no label, UUID=b89db579-d023-4e5b-b194-c148b90f357c >>>> Mount special file systems >>>> Checking for updates Hit:1 http://deb.debian.org/debian bookworm InRelease Get:2 http://security.debian.org/debian-security bookworm-security InRelease [48.0 kB] Get:3 http://deb.debian.org/debian bookworm/main Sources [9496 kB] Get:4 http://security.debian.org/debian-security bookworm-security/contrib Sources [856 B] Get:5 http://security.debian.org/debian-security bookworm-security/non-free-firmware Sources [796 B] Get:6 http://security.debian.org/debian-security bookworm-security/main Sources [145 kB] Get:7 http://security.debian.org/debian-security bookworm-security/main arm64 Packages [242 kB] Get:8 http://security.debian.org/debian-security bookworm-security/main Translation-en [147 kB] Get:9 http://security.debian.org/debian-security bookworm-security/contrib arm64 Packages [508 B] Get:10 http://security.debian.org/debian-security bookworm-security/contrib Translation-en [652 B] Get:11 http://security.debian.org/debian-security bookworm-security/non-free-firmware Translation-en [472 B] Get:12 http://deb.debian.org/debian bookworm/non-free-firmware Sources [6436 B]                    Get:13 http://deb.debian.org/debian bookworm/non-free Sources [77.9 kB]                            Get:14 http://deb.debian.org/debian bookworm/contrib Sources [51.4 kB]                            Get:15 http://deb.debian.org/debian bookworm/main Translation-en [6109 kB]                        Get:16 http://deb.debian.org/debian bookworm/contrib arm64 Packages [45.6 kB]        Get:17 http://deb.debian.org/debian bookworm/contrib Translation-en [48.8 kB]        Get:18 http://deb.debian.org/debian bookworm/non-free arm64 Packages [75.8 kB]        Get:19 http://deb.debian.org/debian bookworm/non-free Translation-en [67.0 kB]        Get:20 http://deb.debian.org/debian bookworm/non-free-firmware arm64 Packages [5832 B]        Get:21 http://deb.debian.org/debian bookworm/non-free-firmware Translation-en [20.9 kB]        Fetched 16.6 MB in 36s (461 kB/s)        Reading package lists... Done Reading package lists... Done Building dependency tree... Done Calculating upgrade... Done The following packages will be upgraded:   libgnutls30 libtasn1-6 2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 1359 kB of archives. After this operation, 8192 B disk space will be freed. Get:1 http://security.debian.org/debian-security bookworm-security/main arm64 libtasn1-6 arm64 4.19.0-2+deb12u1 [46.0 kB] Get:2 http://security.debian.org/debian-security bookworm-security/main arm64 libgnutls30 arm64 3.7.9-2+deb12u4 [1313 kB] Fetched 1359 kB in 6s (230 kB/s)        E: Can not write log (Is /dev/pts mounted?) - posix_openpt (19: No such device) (Reading database ... 11702 files and directories currently installed.) Preparing to unpack .../libtasn1-6_4.19.0-2+deb12u1_arm64.deb ... Unpacking libtasn1-6:arm64 (4.19.0-2+deb12u1) over (4.19.0-2) ... Setting up libtasn1-6:arm64 (4.19.0-2+deb12u1) ... (Reading database ... 11702 files and directories currently installed.) Preparing to unpack .../libgnutls30_3.7.9-2+deb12u4_arm64.deb ... Unpacking libgnutls30:arm64 (3.7.9-2+deb12u4) over (3.7.9-2+deb12u3) ... Setting up libgnutls30:arm64 (3.7.9-2+deb12u4) ... Processing triggers for libc-bin (2.36-9+deb12u9) ... >>>> Installed additional firmware files >>>> Installing kernel Hit:1 http://security.debian.org/debian-security bookworm-security InRelease Hit:2 http://deb.debian.org/debian bookworm InRelease Get:3 https://laban.lysator.liu.se/pub/opensuse/repositories/home:/danielthompson/Debian_Testing ./ InRelease [1549 B] Ign:3 https://laban.lysator.liu.se/pub/opensuse/repositories/home:/danielthompson/Debian_Testing ./ InRelease Get:4 https://laban.lysator.liu.se/pub/opensuse/repositories/home:/danielthompson/Debian_Testing ./ Packages [2495 B] Fetched 4044 B in 4s (1053 B/s)    Reading package lists... Done W: GPG error: https://laban.lysator.liu.se/pub/opensuse/repositories/home:/danielthompson/Debian_Testing ./ InRelease: The following signatures were invalid: EXPKEYSIG 1CC38EB6DADC6EA2 home:danielthompson OBS Project <home:danielthompson@build.opensuse.org> Reading package lists... Done Building dependency tree... Done Reading state information... Done The following additional packages will be installed:   linux-image-5.7.0-2-pinebookpro-arm64 The following NEW packages will be installed:   linux-image-5.7.0-2-pinebookpro-arm64 linux-image-pinebookpro-arm64 0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded. Need to get 34.0 MB of archives. After this operation, 173 MB of additional disk space will be used. Get:1 https://laban.lysator.liu.se/pub/opensuse/repositories/home:/danielthompson/Debian_Testing ./ linux-image-5.7.0-2-pinebookpro-arm64 5.7.19-30-geadcd756eb47-1 [34.0 MB] Get:2 https://laban.lysator.liu.se/pub/opensuse/repositories/home:/danielthompson/Debian_Testing ./ linux-image-pinebookpro-arm64 5.7.19-30-geadcd756eb47-1 [1664 B]        Fetched 34.0 MB in 1min 5s (526 kB/s)        E: Can not write log (Is /dev/pts mounted?) - posix_openpt (19: No such device) Selecting previously unselected package linux-image-5.7.0-2-pinebookpro-arm64. (Reading database ... 11702 files and directories currently installed.) Preparing to unpack .../linux-image-5.7.0-2-pinebookpro-arm64_5.7.19-30-geadcd756eb47-1_arm64.deb ... Unpacking linux-image-5.7.0-2-pinebookpro-arm64 (5.7.19-30-geadcd756eb47-1) ... electing previously unselected package linux-image-pinebookpro-arm64. Preparing to unpack .../linux-image-pinebookpro-arm64_5.7.19-30-geadcd756eb47-1_arm64.deb ... Unpacking linux-image-pinebookpro-arm64 (5.7.19-30-geadcd756eb47-1) ... Setting up linux-image-5.7.0-2-pinebookpro-arm64 (5.7.19-30-geadcd756eb47-1) ... update-initramfs: Generating /boot/initrd.img-5.7.0-2-pinebookpro-arm64 W: No zstd in /usr/bin:/sbin:/bin, using gzip W: Possible missing firmware /lib/firmware/ene-ub6250/ms_rdwr.bin for built-in driver ums_eneub6250 W: Possible missing firmware /lib/firmware/ene-ub6250/msp_rdwr.bin for built-in driver ums_eneub6250 W: Possible missing firmware /lib/firmware/ene-ub6250/ms_init.bin for built-in driver ums_eneub6250 W: Possible missing firmware /lib/firmware/ene-ub6250/sd_rdwr.bin for built-in driver ums_eneub6250 W: Possible missing firmware /lib/firmware/ene-ub6250/sd_init2.bin for built-in driver ums_eneub6250 W: Possible missing firmware /lib/firmware/ene-ub6250/sd_init1.bin for built-in driver ums_eneub6250 W: Possible missing firmware /lib/firmware/xc3028L-v36.fw for built-in driver tuner_xc2028 W: Possible missing firmware /lib/firmware/xc3028-v27.fw for built-in driver tuner_xc2028 W: Possible missing firmware /lib/firmware/dvb-fe-xc5000c-4.1.30.7.fw for built-in driver xc5000 W: Possible missing firmware /lib/firmware/dvb-fe-xc5000-1.6.114.fw for built-in driver xc5000 W: Possible missing firmware /lib/firmware/dvb-fe-xc4000-1.4.fw for built-in driver xc4000 W: Possible missing firmware /lib/firmware/dvb-fe-xc4000-1.4.1.fw for built-in driver xc4000 P: Found /usr/lib/linux-image-5.7.0-2-pinebookpro-arm64/rockchip/rk3399-pinebook-pro.dtb P: Checking for EXTLINUX directory... not found. P: Creating EXTLINUX directory... done: /boot/extlinux P: Writing config for vmlinuz-5.7.0-2-pinebookpro-arm64... P: Updating /boot/extlinux/extlinux.conf... Setting up linux-image-pinebookpro-arm64 (5.7.19-30-geadcd756eb47-1) ... >>>> Basic configuration Choose a hostname (or press Return to keep default): usb About to create main user, please enter username: ghost Adding user `ghost' ... Adding new group `ghost' (1000) ... Adding new user `ghost' (1000) with group `ghost (1000)' ... Creating home directory `/home/ghost' ... Copying files from `/etc/skel' ... New password: Retype new password: passwd: password updated successfully Changing the user information for ghost Enter the new value, or press ENTER for the default Full Name []: Der Geist der Maschine Room Number []: Work Phone []: Home Phone []: Other []: Is the information correct? [Y/n] y Adding new user `ghost' to supplemental / extra groups `users, users' ... Adding user `ghost' to group `users' ... adduser: The user `ghost' is already a member of `users'. Adding user `ghost' to group `sudo' ... Done. Generating locales (this might take a while)... Generation complete. Current default time zone: 'US/Pacific' Local time is now:      Fri Mar 14 17:33:18 PDT 2025. Universal Time is now:  Sat Mar 15 00:33:18 UTC 2025. >>>> Task selection <text based gui for choosing a desktop environment shows up> >>>> umount
Booting from usb requires tow-boot which I don't have.  Here is a sanity check: /dev/sda5 is the boot partition and we find all the files we expect there.
manjaro:~/pinebook-pro-debian-installer-new$ sudo mount /dev/sda5 /mnt/tmp manjaro:~/pinebook-pro-debian-installer-new$ ls /mnt/tmp/ System.map-5.7.0-2-pinebookpro-arm64  config-5.7.0-2-pinebookpro-arm64 efi  extlinux  initrd.img-5.7.0-2-pinebookpro-arm64  lost+found  rk3399-pinebook-pro.dtb  vmlinuz-5.7.0-2-pinebookpro-arm64 manjaro:~/pinebook-pro-debian-installer-new$ sudo umount /mnt/tmp
If I recall, previously you had some issues with running the debian-installer from Manjaro. I recommend you a) to start from a fresh git clone and b) add "set -x" to the debian installer for verbose output. Then post the whole output and not just single lines.
and I tried again, with ....-new , and got same result
a git clone to a mrfixit sd
+ '[' -z '' ']'
+ mkdir -p /home/d/Downloads/pinebook-pro-debian-installer-new/sysimage
+ sudo mount /dev/sda6 /home/d/Downloads/pinebook-pro-debian-installer-new/sysimage
+ sudo mkdir -p /home/d/Downloads/pinebook-pro-debian-installer-new/sysimage/boot
+ sudo mount /dev/sda5 /home/d/Downloads/pinebook-pro-debian-installer-new/sysimage/boot
+ sudo mkdir -p /home/d/Downloads/pinebook-pro-debian-installer-new/sysimage/boot/efi
+ sudo mount /dev/sda4 /home/d/Downloads/pinebook-pro-debian-installer-new/sysimage/boot/efi
+ do_debootstrap
+ '[' '!' -z ']'
+ '[' '!' -e debootstrap-bookworm-arm64.tar.gz ']'
+ sudo debootstrap --arch=arm64 --include ca-certificates,console-setup,cryptsetup-initramfs,initramfs-tools,locales,keyboard-configuration,sudo,u-boot-menu,gnupg,tasksel bookworm /home/d/Downloads/pinebook-pro-debian-installer-new/sysimage
E: Release signed by unknown key (key id F8D2585B8783D481)
+ do_umount
>>>> umount
+ sudo umount /home/d/Downloads/pinebook-pro-debian-installer-new/sysimage/boot/efi
+ true
+ true
+ sudo umount /home/d/Downloads/pinebook-pro-debian-installer-new/sysimage/dev
umount: /home/d/Downloads/pinebook-pro-debian-installer-new/sysimage/dev: mountpoint not found
+ sudo umount /home/d/Downloads/pinebook-pro-debian-installer-new/sysimage/proc
umount: /home/d/Downloads/pinebook-pro-debian-installer-new/sysimage/proc: mountpoint not found
+ sudo umount /home/d/Downloads/pinebook-pro-debian-installer-new/sysimage/sys
umount: /home/d/Downloads/pinebook-pro-debian-installer-new/sysimage/sys: mountpoint not found
+ true
+ '[' '!' -z '' ']'
BTW, boot_targets has usb0 in it, before emmc., I'm not sure which socket that is
(03-15-2025, 04:51 PM)wdt Wrote: a git clone to a mrfixit sd
Let me quote myself:
Der Geist der Maschine Wrote:Copying over the config files is a hack and I do not know in what follow up issue you may run.
Mr Fixit's debootstrap is very old. A little bit of guesswork: the signature keys come with debootstrap and are too old for the Debian Bookworm packages.
Either manually install a recent debootstrap package on Mr Fixit's Debian 9 or run in the installer from (a somewhat recent) Manjaro. For the latter, see my previous post on how flawless that worked.
Next time, please share the complete logs.
Since Manjaro Stable hadn't updated in a year, I switched to Manjaro Testing about a month and a half ago, on March 14th.
The wiki has an article on how to do it:
https://wiki.manjaro.org/index.php/Switching_Branches
And I wanted to say nothing had gone wrong. But.
systemd has this truly evil feature, where the default configuration is for it to delete files in /tmp after 10 days, and in /var/tmp/ after 30 days, without any warning that your data is going to start disappearing.
I'd disabled this in Manjaro Stable several years ago, and somehow after moving to Testing this evil gremlin came back again. I lost a lot of files in /var/tmp that I wasn't done with after 30 days.
$ man tmpfiles.d
Quote:Files in /etc/tmpfiles.d override files with the same name in /usr/lib/tmpfiles.d and /run/tmpfiles.d. Files in /run/tmpfiles.d override files with the
same name in /usr/lib/tmpfiles.d. Packages should install their configuration files in /usr/lib/tmpfiles.d. Files in /etc/tmpfiles.d are reserved for the
local administrator, who may use this logic to override the configuration files installed by vendor packages.
And I am supposed to know that by telepathy, right?
So I have copied /usr/lib/tmpfiles.d/tmp.conf to /etc/tmpfiles.d/tmp.conf and changed contents of the "aging" fields to "-" . We'll see if that keeps the gremlin off. But that should be the default.
And even wiki.archlinux.org now has a JS captcha, what the shit?
[Image: eoagz0.png]
Quote:Ultimately, this is a hack whose real purpose is to give a "good enough" placeholder solution so that more time can be spent on fingerprinting and identifying headless browsers (EG: via how they do font rendering) so that the challenge proof of work page doesn't need to be presented to users that are much more likely to be legitimate.
I don't want anything to be able to fingerprint my browser, especially by how it renders fonts. That's a browser bug that needs to be fixed.
Quote:Please note that Anubis requires the use of modern JavaScript features that plugins like JShelter will disable. Please disable JShelter or other such plugins for this domain.
And what is JShelter?
https://jshelter.org/
Quote:An anti-malware Web browser extension to mitigate potential threats from JavaScript, including fingerprinting, tracking, and data collection!
So Arch Wiki now requires support for "modern" features like "fingerprinting, tracking, and data collection".
Unfortunately, more and more of the Internet is getting infected with this "protection" disease, be it the centralized Cloudflare one or the Anubis software (FOSS) that website admins can deploy locally. Blame the LLM bots for that mess!
And suddenly all of Stack Exchange is showing a Cloudflare wall page. I'm going to become Amish, I have a real nice horse picked out.
Horse: "Would you like to subscribe to enable self-driving?"
Updating with issues I've had with Manjaro Testing and fixes.
- gnumeric is out of date.
gnumeric: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
Solution: Switch to sc.
- mutt was out of date and holding back upgrading multiple gpg-related packages.
Solution: Switch to mutt-git.
That just got fixed by today's update, so can switch back.
- The system won't boot
Solution: Go back in time. Before switching to manjaro-testing, make sure my rescue SD card image is fully up-to-date. Test booting immediately after switching, so I don't find out months later at the worst possible time.
So... what happened here?
I'm using lvm2. That means you need to edit /etc/mkinitcpio.conf to add the lvm2 hook. That change needs to stay in the system file, because every time there's a kernel update, the initramfs-linux.img is rebuilt. New upstream files are supposed to land at /etc/mkinitcpio.conf.pacnew, allowing you to manually merge any changes you want.
I do have a mkinitcpio.conf.pacnew, but for some reason, the lvm2 configuration disappeared from the main file. Check for that after switching to manjaro-testing. I don't know if that's when it happened.
Steps to fix using arch-chroot:
$ sudo pacman -Syu arch-install-scripts
$ sudo mount /dev/VG1/LV1 /mnt # mount the root volume you want to fix
$ sudo archlinux-chroot /mnt
# vi /etc/mkinitcpio.conf
# mount /dev/mmcblk2p1 /boot # mount the corresponding boot volume within the chroot
# mkinitcpio -P
I'm using the Megi kernel. I also have the default 6.15.5-1-MANJARO-ARM kernel supplied by manjaro-testing installed. I use the initramfs-linux.img built against the manjaro-testing kernel, not the megi kernel, in extlinux.conf for booting. Some day I'll go back and figure out why, but it's working.
If I hadn't written up using lvm on my new emmc for the forum, it would have taken much longer to find and fix this. My notes taken for myself were too terse.
Another "fun" discovery while bringing the rescue SD card image up to date to fix this:
tomb-git (version 2.11.r76.g586b5cb-1) could not open tomb files created by tomb 2.10 installed from tarball.
It just says incorrect password and makes you think you forgot your volume encryption password on top of everything else.
I found the old Tomb-2.10 directory still hanging around in my build directory after mounting the emmc. Installed directly from that to the SD card's filesystem and then it worked.
  PBP does not start from postmarket OS image burnt to sd card zkajdan 21 18,830 03-10-2025, 01:55 PM
  Pinebook Pro upgrading from the factory image yamsoup 12 18,097 02-22-2024, 04:02 PM
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 7,603 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  postmarketOS/Alpine edge image for the Pinebook Pro MartijnBraam 74 210,640 08-24-2022, 02:06 PM
Last Post: petersen77
  Debian/unstable SD card rescue image vajak 4 9,438 10-28-2021, 02:53 PM
Last Post: vajak
Brick Anyone know of a good firewall? SpaceLord 6 12,793 07-24-2021, 12:04 PM
Last Post: globaltree
  Good i3 Config file to use? User 22018 6 13,765 06-17-2021, 09:38 AM
Last Post: user526
  Recalbox Image is available Luke 8 27,181 01-31-2021, 12:00 PM
Last Post: rimaille
  eMMC Trouble After Flashing WRONG Image balin 7 15,469 12-29-2020, 04:24 PM
  PBP not starting up sometimes / [Firmware Bug]: Kernel image misaligned at boot pato3 8 17,684 10-17-2020, 09:52 AM
