PBP does not start from postmarket OS image burnt to sd card
#21
(03-10-2025, 08:16 AM)tophneal Wrote:
(03-07-2025, 06:54 PM)wdt Wrote: is it a 1 or 2 partition image?
uboot will be looking for either boot,scr or extlinux.conf or aarch64.efi  (only 1)
any of these must be in correct location
as well, sometimes the paths in extlinux.conf can be wrong, paths are  in relation to itself,
I had that happen only last week from my inherited son's pbp
OP is trying to boot an install SD of TowBoot
yes exactly @tophneal  @wdt I'm trying to install TowBoot from spi, but I get a u-boot prompt (if I interrupt the boot - otherwise it's the never-stopping message/question from the photo above) whichever way the emmc switch is flipped...
thanks!!
Well, the 1st post was about installing post-market or repairing manjaro
from the uboot prompt,,,, mmc scan ,,,, setenv boot_target MMC1,,, printenv boot_target ,,,, boot
  What's a good image to use now? [tutorial help as well] frank_philip 40 33,262 07-18-2025, 07:28 PM
Last Post: Dendrocalamus64
  Pinebook Pro upgrading from the factory image yamsoup 12 17,970 02-22-2024, 04:02 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 6,498 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Postmarket OS passcode ionmich 1 2,653 06-30-2023, 02:25 PM
Last Post: jakfish
  2TB SD Card Write Errors jiacovelli 3 4,435 06-02-2023, 06:13 PM
  Bootloader: SD card boot quirks crazyquark 1 3,347 10-04-2022, 12:27 PM
Last Post: elitegamercody
  Unable to make a bootable microSD card myself600 15 16,661 09-27-2022, 01:45 PM
Last Post: myself600
  postmarketOS/Alpine edge image for the Pinebook Pro MartijnBraam 74 209,860 08-24-2022, 02:06 PM
Last Post: petersen77
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 29,872 08-18-2022, 11:26 PM
Last Post: calinb
  Debian/unstable SD card rescue image vajak 4 9,402 10-28-2021, 02:53 PM
Last Post: vajak
