Keyboard issue
Keyboard issue
https://forum.armbian.com/topic/47099-ke...are-issue/
Is there any chance to check if the keyboard failure is hardware or software related?
The keyboard stopped working correctly when computer was in the drawer. There was no possibility for any physical damage to the keyboard.
Can I solve the issue by myself or do I need to buy the new keyboard or use my Pinebook pro as a coaster only.
Thanks.
*UPDATE*
On top of keyboard issue - I solved it by buying external usb keyboard.
*I cannot power up my trashy laptop i.e. PBP.*
1a. battery disconnected, I used bypass cables.
eMMC with Armbian
U-Boot TPL 2020.10-armbian (Aug 08 2021 - 16:26:56)
Channel 0: LPDDR4, 50MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB
Channel 1: LPDDR4, 50MHz
256B stride
lpddr4_set_rate: change freq to 400000000 mhz 0, 1
lpddr4_set_rate: change freq to 800000000 mhz 1, 0
Trying to boot from BOOTROM
Returning to boot ROM...
U-Boot SPL 2020.10-armbian (Aug 08 2021 - 16:26:56 +0200)
Trying to boot from MMC2
NOTICE:  BL31: v2.5(release):c158878-dirty
NOTICE:  BL31: Built : 16:26:51, Aug  8 2021
U-Boot 2020.10-armbian (Aug 08 2021 - 16:26:56 +0200)
SoC: Rockchip rk3399
Reset cause: POR
Model: Pine64 Pinebook Pro
DRAM:  3.9 GiB
PMIC:  RK808
MMC:  mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from SPIFlash... Invalid bus 0 (err=-19)
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In:    serial
Out:  serial
Err:  serial
Net:  No ethernet found.
starting USB...
Bus usb@fe380000: failed to get usb phy
Port not available.
Bus usb@fe3a0000: failed to get usb phy
Port not available.
Bus usb@fe3c0000: failed to get usb phy
Port not available.
Bus usb@fe3e0000: failed to get usb phy
Port not available.
Bus dwc3:
All led are dead.
1b. - eMMC is disabled, Armbian on sd card
256B stride
Trying to boot from MMC1
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:  serial
Err:  serial
2. Battery is connected (with reset), eMMC disabled.
256B stride
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:  serial
Err:  serial
All led are dead.
Do you think that it’s a sign of a software issue rather than hardware?
[/url]
[url=https://forum.armbian.com/topic/47099-keyboard-is-it-software-issue/]https://forum.armbian.com/topic/47099-keyboard-
Geometry Dash Lite-is-it-software-issue/
I'm confused because PBP was stored in a drawer after update&&upgrade.
What could happen to the keyboard in the drawer? I have no idea. That's why I thought  that maybe this is somehow firmware related?
I have had a lot hardware and software related issues with PBP. To be honest with this device everything is possible.
The thing is, how can I exclude software or hardware defect without investing money in the new keyboard? I don't want to invest >$1 in this product anymore.
Put a different OS on a micro-SD card. Boot that and see what happens.
On these devices there is certainly the possibility of hardware damage if stored in a drawer. The battery can puff up and cause mechanical damage. I've had it happen. I haven't had damage to the keyboard but I can see how it could happen. I don't suspect this is your issue though.
In any case if you get to a point where you give up on it please don't "recycle" it. There are many of us here who would jump at the opportunity to try to fix it.
:wq
Question Pinebook pro dead / keyboard issue? / Troubleshooting Mengalef 2 4,618 12-05-2024, 04:16 PM
  Keyboard unresponsive after some idle time in uboot Trinatriumcitrat 1 3,897 11-25-2024, 03:42 PM
  Dead Pinebook Pro Keyboard Keys calinb 2 4,215 09-02-2023, 12:31 PM
Last Post: calinb
  power on Pinebook Pro mainboard without keyboard? papable 0 2,879 07-20-2023, 11:06 PM
Last Post: papable
  Newbie with immediate issue jasonumd 1 3,589 03-04-2023, 05:59 PM
Last Post: hacknix
  ISO keyboard Pinebook pro for sale tgrauss 3 7,168 11-01-2022, 04:45 AM
Last Post: tgrauss
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 6,356 10-08-2022, 06:22 PM
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 9,159 09-14-2022, 03:56 AM
Last Post: Carl
  suckless surf on arch linux pinebook pro scrolling issue gehn5 0 2,802 04-16-2022, 07:41 PM
Last Post: gehn5
  Selling PineBook PRO with ISO Keyboard + NVME firefox-58 27 38,994 04-08-2022, 06:23 AM
Last Post: firefox-58
