Alarm clock doesn’t work
Have you definitely tried both the suggestions in this thread. Both the command line options for clocks and pothos's app work perfectly for me?
The app https://gitlab.gnome.org/kailueke/wake-mobile does not support multiple alarms currently but another workaround to have multiple alarms is to use gnome-clocks with this script to run after setting a new alarm in order to wake the phone from suspend (https://gitlab.com/mobian1/issues/-/issu..._547667815):
https://git.launchpad.net/debinst/tree/mobian/clks.sh (which depends on https://git.launchpad.net/debinst/tree/mobian/clks.py)
I don't know if it is possible to run the script automatically every time we close the gnome-clocks window on Phosh.
The workaround mentioned is working even when the alarm app is closed and after phone reboot.
Update: on https://gitlab.gnome.org/GNOME/gnome-clo...te_1640507, someone also mentioned https://github.com/Dejvino/birdie which is a fork of wake-mobile.
(08-02-2024, 01:30 PM)baptx Wrote: The app https://gitlab.gnome.org/kailueke/wake-mobile does not support multiple alarms currently but another workaround to have multiple alarms is to use gnome-clocks with this script to run after setting a new alarm in order to wake the phone from suspend (https://gitlab.com/mobian1/issues/-/issu..._547667815):
Which version of Mobian do you use? Gnome Clocks still produces no sound for me, I use Mobian Trixie. My workaround consists in using the "at" command with the "play" command.
(08-16-2024, 03:18 AM)anonymous Wrote: Which version of Mobian do you use? Gnome Clocks still produces no sound for me, I use Mobian Trixie. My workaround consists in using the "at" command with the "play" command.
I don't often connect here and just saw your message. I am using Mobian stable (with Mobian testing kernel for video recording: https://gist.github.com/baptx/7faaaf876e...25bde41625).
How can we cancel the wake-mobile alarm completely?
the GUI doesn't seem to work for that, is there a way to send a direct dmesg command?
even after I click 'STOP' it still shows countdown to the new time I set.
  The program doesn`t detect the camera blag0rag 6 6,853 09-17-2024, 03:45 PM
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 7,730 09-05-2023, 11:16 AM
Last Post: nickolas
  Chatty does not work after suspend mode user641 4 7,094 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  Wifi doesn't work after update nickolas 2 4,843 04-14-2023, 10:07 AM
Last Post: nickolas
  Most recent Mobian image or installer image known to work? DrPlamsa 13 16,653 02-26-2023, 11:47 PM
Last Post: SukiiPooru
  German Emergency Alarm System Test arno_nuehm 4 6,490 12-11-2022, 01:44 PM
Last Post: traut
Exclamation The webcam doesn't work in Firefox anonymous 0 2,380 11-06-2022, 01:45 PM
Last Post: anonymous
  Megapixels doesn't work Glenn 4 7,945 08-28-2022, 03:19 PM
Last Post: vortex
  PP Keyboard doesn't charge Pinephone (Mobian) jojuma 1 3,391 08-06-2022, 01:10 AM
Last Post: elode
  Can't Get Nheko To Work [never mind, it's a bug] el.pollo.diablo 0 2,295 08-02-2022, 02:11 AM
Last Post: el.pollo.diablo
