Future RK3588 model
#21
realisticconsumer:
    The original pbp is perfect already
That's your take on it. While I'm quite with you for the other part (mainly that it should keep its low price), I beg to differ on the "perfect" part.
My gripes are shared with others in this thread:
- Add a door (secured with screws) at the underside. And be careful to make all useful things accessible through it.
  Opening the pbp is a *royal pita* and also it is really fragile.
- Ease the unbrick process
  The term "unbrick" should be taken with a grain of salt (in the wound that is:
  opening the laptop shoud never be needed, except maybe for HW problems,
  like repairing something or changing the battery).
  Always try to boot from SD first, we really don't care the milliseconds delay that will cost us.
  Or make an externally & easily accessible HW switch to chose the boot device. (through the door).
  You always should be able to boot from external storage.
  Having SPI is fantastic, if and only if you can easily get out of problems.
  Ultra easy to unbrick, will attract firmware developpers, or at least ease the adoption by aspiring ones.
  Do not rely on proprietary solutions (rkdeveloptools) for unbricking, even if they are nice to also have.
- kbd & touchpad firmware completely FOSS.
  Really nothing else to add here. There will be bugs / things to fix.
  I also like the idea of separating the power button from the kbd (and its firmware), and then put back the "suppr" key.
- Be sure to choose components with a lot of rewrite cycles for storing firmwares.
  SPI, kbd, touchpad, etc.
- The shared serial console / headphone connector, why ?
  Put a USB-serial chip on the board, and add a dedicated external USB port for it (like on the qp64).
  Anyone who have problems will have the right cable available to get help. I.e.: less angry people on the forums.
- The emmc (if there is one) should always be socketed, and externally accessible (through the door).
- I like the idea of internal usb port(s) to plug things like a wifi dongle. I'd make that at least 2. And you can then avoid having an integrated wifi/BT chip on the board. (make those USB ports accessible through the door).
- If there is a reset button / switch it should be accessible. (through the door or even better above the keyboard).
- While the keyboard combo killswitches for camera, wifi, BT are nice to have. A pack of 3 HW jumpers on the mainboard would be sufficient and will cater for a lot of people's demand for such. (through the door).
- The nvme situation with the optional adapter cable needs to be handled more sanely. Add a real M.2 socket or don't do it at all.
  If you add a socket (I think you should), make it available through the door.
- Power handling should be straightened, I'm not advocating for any plug type, I think EU authorities have chosen.
  But make the power handling bulletproof.
  Drained battery should not matter at all.
  The laptop shoud run properly without a battery installed (without having to do anything, like plugging an almost inaccessible internal cable).
EDIT: - I'd rather have good sound jack (separate from serial console), than integrated speakers.
I personally would be willing to pay a bit more to have those points fixed properly. Don't get obsessed with the 200€/$ target we can understand that better is pricier, up to a reasonable point.
Thanks a lot
Keep it efficient and simple. Smile
As for me, I'm eyeing Lenovo x13s and Apple's laptops with M2 for next laptop. I'm just waiting for the gnu/linux to mature on these platforms and for my >10 years old lenovo laptop to die. Then I'll switch.
I think Pine could develop a PBP2 board to replace the main board to address many of the issues without making a new case.
This could address:
+ new SoC
+ power/battery connection usage (solve jumper wires)
+ internal USB A
+ internal-only UART console pins
+ towboot preinstalled to SPI and set to boot usb first, sd, nvme, ahci, emmc, spi, pxe last
And a few more could be address with a new case bottom:
+ add easy-access door above main board
But wouldn't address many:
- still POWER instead of DEL key
- same trackpad/keyboard firmware write cycle limits
- same USB2 on headphone/uSD card board
I would happily buy an updated main board! Seems like there’s little interest in the pbp though.
Has Pine64 even made back their development costs on the PBP? While they might not consider a full laptop re-design, the cost to design just the board should be less overall than an entirely new laptop.
While I'd love to see even a board replacement to a newer SoC with the suggested improvements, the price would need to be set right. I'm not sure if I would pay another $200 just to replace the board with a better one. I might, but I would need to consider for a long while...
This is basically a rk3588 pbpro
https://www.aliexpress.com/item/1005005988693513.html
  Center touchpad under typing keys in future versions? Damon 3 8,764 03-21-2020, 02:01 PM
Last Post: Dendrocalamus64
  3d model files? odinson 0 3,058 11-16-2019, 03:34 PM
Last Post: odinson
  Future ANSI Keyboard Option? Updates? u974615 6 17,090 11-04-2019, 11:40 PM
  Pine book Pro motherboard future upgrades ? bcnaz 2 7,958 10-15-2019, 04:06 PM
Last Post: bcnaz
