GPIO breakout question
Hello, gonna front-load this with an apology for my utter newbness, and probably a whole slew of subsequent dumb questions.
I have a thought and I would like to ask if this is something that is possible. I was thinking about how one could go about getting access to, or expanding, the GPIO resources for the Pinebook Pro. In my searching around for existing info, I found the following:
https://forum.pine64.org/showthread.php?tid=4785
I'm not so enthusiastic about doing everything through the SD card slot like that, but I def appreciate that that user was able to really probe the system for that functionality like that.
I had another thought: is it possible to create some kind of add-on board/card using the PCIe x4 connection, some kind of bridge chip, and possibly some kind of MCU or other supporting ICs, that one could install through the M.2 connection, and then create a port physically somewhere on the case (I'm actually thinking of somehow machining the aluminum bottom case somehow to do this but whole other can of worms)? A whole "GPIO board" mounted on that connection using that bus?
Is that dumb? Crazy amount of work? I'm not even sure where to start, mostly just wanted a lot more GPIO/physical computing ability for this platform.
(01-17-2023, 06:13 AM)pinus_pinea Wrote: I had another thought: is it possible to create some kind of add-on board/card using the PCIe x4 connection, some kind of bridge chip, and possibly some kind of MCU or other supporting ICs, that one could install through the M.2 connection, and then create a port physically somewhere on the case (I'm actually thinking of somehow machining the aluminum bottom case somehow to do this but whole other can of worms)? A whole "GPIO board" mounted on that connection using that bus?
Yes, it's possible. PCIe/UART bridges exist, but I suggest starting with an internal USB hub and a USB to UART bridge. I'd recommend modifying the below project to hold a USB/UART bridge, then manually running the USB connection from the test points on the board. I'm not an EE, but I believe you should be able to drop the UART bridge project's component set into the PBP WiFi project in KiCad. Then, with some layout and routing, you should be good to go
https://github.com/TobleMiner/PBP-NGFF-A-E-adapter
https://github.com/jiegec/HT42B534USB2UART (any other project like this should work but this one is just what i plucked off google)
  Newbie Question!! oniichann 3 4,868 10-26-2023, 07:09 AM
  Wont charge when powered off, and update question pineymousepad 7 14,417 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Network connection question??? davehetfield 1 6,526 03-11-2021, 07:31 AM
Last Post: tkudog
  Novice question: Pinebook Pro does boot (does it?) but black screen Gert V. 21 35,510 01-27-2021, 10:48 PM
Last Post: rimaille
Brick Battery / power question GloriousCoffee 3 7,433 02-13-2020, 10:02 AM
Last Post: rleasle
  Hardware video decoding question sgx2 1 4,860 01-15-2020, 01:48 PM
Last Post: RotatingNut
  Silly question: Stadia on PBP? fpex73 0 3,364 01-11-2020, 08:08 AM
Last Post: fpex73
  Question About PineBook Pro Orders bebop_man 4 10,498 10-16-2019, 03:35 PM
