HDMI to DVI Color issues?
Sad
I recently received my 64+ board and have loaded Debian on it successfully using an HDMI cable to my TV.
I then tried the same HDMI cable connected to an HDMI to DVI Adapter to my computer monitor and while I can operate the system, it has a purple/pink tint to the entire screen.
I've tried various cables with same result.  I tried the DVI connector with same HDMI cable on another system (lattepanda windows board) and it worked fine (no tint).
Is there a setting or something I need to set on this board to get it to work properly via a DVI connector?
Any help is appreciated.
THANKS
HDMI -> DVI is an issue.
What you are experiencing is due to the display driver changing the colour mode from RGB to YPbPr when you use an adaptor. Currently, your only option is using an active adaptor - those aren't cheap however.
some monitor/tv have an option to reset color and/or selection of a color mode. if your display has that you could try that. i had a similar tint issue which was fixed by using a reset color option.
(06-14-2016, 05:49 PM)dkryder Wrote: some monitor/tv have  an option to reset color and/or selection of a color mode. if your display has that you could try that. i had a similar tint issue which was fixed by using a reset color option.
Indeed, I forgot to mention this-- thanks.
(06-14-2016, 01:43 PM)leatherlips Wrote: I recently received my 64+ board and have loaded Debian on it successfully using an HDMI cable to my TV.
THANKS
I had this problem too. My monitor is a Dell U2412 and in its menus it has a color setting of either RGB or YPbPr. I set it to YPbPr and it works fine now.
THANKS
I believe that using sunxidrm would also work.
  Would HDMI screen for Raspberry PI work? dhewko 1 5,704 07-23-2017, 06:43 AM
Last Post: MarkHaysHarris777
Exclamation HDMI 1024 x 600 mus1c 4 10,192 01-09-2017, 07:30 AM
Last Post: mus1c
  HDMI-DVI aminhb 11 28,136 01-08-2017, 10:52 AM
Last Post: Luke
  HDMI issues rahlquist 35 72,698 12-24-2016, 02:20 AM
Last Post: sboyce
  Monitor no output (through HDMI to DVI adaptor) gam01hr 10 24,400 11-15-2016, 01:46 PM
Last Post: Armbian User
  HDMI CEC ayufan 15 30,391 09-08-2016, 10:24 AM
Last Post: ayufan
  HDMI to VGA adapter for Android PineA64 tech support setup MarkHaysHarris777 0 3,924 08-06-2016, 12:47 PM
  hdmi_group CEA or DMT hdmi group specify uEnv.txt MarkHaysHarris777 2 8,133 07-01-2016, 08:23 AM
  No CEC over HDMI? utdrmac 2 8,827 03-07-2016, 03:05 PM
Last Post: utdrmac
  HDMI 3D, ARC + Ethernet Channels? bigmacattack 4 17,248 01-29-2016, 06:29 PM
Last Post: StefanB
