Pinephone boot.
So a good while back, I ordered a pinephone. Mostly to support the project but also because I wanted to use a Linux phone. Unfortunately, before I got to use it, AT&T did their whitelist thing then Verizon bought Tracfone et al which caused not a small amount of grief so the Pinephone sat in a drawer for a while.
Anyway, yesterday, I activated a t-mobile sim and put it in the (unupdated) pinephone. Things seemed to be going well. Sent some texts, did some test calls, things were good. So I left it charging. This morning, I came to use it and it appeared to be off. No biggie. Try to boot - red led, red&green led then just the backlight. Wonder if I didn't have things plugged in correctly so make sure charging is all good and leave it for 10 minutes. Same thing happens.
So now we're in troubleshooting mode. vol-up+power, same deal. vol-up+power, same deal. No apparent recovery mode. Time for research. Find the post at the top of this thread. Could be battery? Don't think so (see above) but pull battery and it's giving a good 4.13V so we appear to definitely be in good shape. Next to try jumpdrive. Download the image, flash to SD, insert and... LED is green (yay, something different) but then we're back to the backlight only. Nothing appeared on the screen at all. A couple of attempts to get to recovery mode again that lead to the same result and then a reboot and the phone's been sitting there for 10 minutes with the backlight on. The metal plate inside the phone is warm (but not hot).
So is there anywhere to go from here?
Do you have the serial cable? There may be console messages that would help figure out what's going on.
By the way, I've been using my Pinephone successfully on AT&T for a couple of years now. I simply changed the IMEI to that of the free flip phone they sent me when 3g service was shut down. (Since AT&T provided the phone it's on their whitelist. The flip phone is left unused in a drawer with the battery removed so I know I'm not using someone else's IMEI.)
(05-05-2024, 11:11 AM)Richy_T Wrote: So a good while back, I ordered a pinephone. Mostly to support the project but also because I wanted to use a Linux phone. Unfortunately, before I got to use it, AT&T did their whitelist thing then Verizon bought Tracfone et al which caused not a small amount of grief so the Pinephone sat in a drawer for a while.
is it bad behaving suspend (sleep)?!
i noticed, that phosh does not immediately show suspend option. maybe something needs to be started in a background when suspend option is shown in power submenu.
you didn't tell your o.s.! mobian (and debian) trixie has t64 tansition going on in trixie, which causes headaches.
did you have automatic updates? which is bad idea for beta software.
tow-boot does not have recovery mode, at least not same as in android world. rough options are, normal boot, sdcard boot, and builtin usb jumpdrive mode.
(05-05-2024, 10:39 PM)Zebulon Walton Wrote: Do you have the serial cable? There may be console messages that would help figure out what's going on.
Interesting. I did not know you could change the IMEI as I may have tried to go that way. I can't remember the exact order of events but I think I got the pinephone just before Tracphone/Verizon pushed everyone over.
I don't have the serial cable but I do have the parts to make one. I'll look into making one this week.
(05-05-2024, 11:52 PM)zetabeta Wrote: is it bad behaving suspend (sleep)?!
I can't even get close to suspend/sleep. As far as I can tell, it was working fine the night before but now I can't even get anywhere through the boot process.
It looks to me like the phone is alive. This is what I get booting normally:
U-Boot SPL 2020.07-rc4-11.2 (Jan 31 2021 - 14:19:48 +0000) DRAM: 3072 MiB Trying to boot from MMC2 NOTICE:  BL31: v2.3(debug): NOTICE:  BL31: Built : 14:19:48, Jan 31 2021 NOTICE:  BL31: Detected Allwinner A64/H64/R18 SoC (1689) NOTICE:  BL31: Found U-Boot DTB at 0x4064908, model: Pine64 PinePhone (1.2) INFO:    ARM GICv2 driver initialized INFO:    Configuring SPC Controller INFO:    PMIC: Probing AXP803 on RSB INFO:    PMIC: dcdc1 voltage: 3.300V INFO:    PMIC: dcdc5 voltage: 1.200V INFO:    PMIC: dcdc6 voltage: 1.100V INFO:    PMIC: dldo1 voltage: 3.300V INFO:    PMIC: dldo2 voltage: 1.800V INFO:    PMIC: dldo3 voltage: 2.800V INFO:    BL31: Platform setup done INFO:    BL31: Initializing runtime services INFO:    BL31: cortex_a53: CPU workaround for 843419 was applied INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied NOTICE:  PSCI: System suspend is available via SCPI INFO:    BL31: Preparing for EL3 exit to normal world INFO:    Entry point address = 0x4a000000 INFO:    SPSR = 0x3c9 U-Boot 2020.07-rc4-11.2 (Jan 31 2021 - 14:19:48 +0000) Manjaro Linux ARM CPU:  Allwinner A64 (SUN50I) Model: Pine64 PinePhone (1.2) DRAM:  3 GiB MMC:  Device 'mmc@1c11000': seq 1 is in use by 'mmc@1c10000' mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1 Loading Environment from FAT... *** Warning - bad CRC, using default environment In:    serial@1c28000 Out:  serial@1c28000 Err:  serial@1c28000 starting USB... No working controllers found Hit any key to stop autoboot:  0 switch to partitions #0, OK mmc1(part 0) is current device Scanning mmc 1:1... Found U-Boot script /boot.scr 975 bytes read in 1 ms (952.1 KiB/s) ## Executing script at 4fc00000 gpio: pin 98 (gpio 98) value is 1 gpio: pin 114 (gpio 114) value is 1 19042312 bytes read in 816 ms (22.3 MiB/s) gpio: pin 98 (gpio 98) value is 0 51342 bytes read in 5 ms (9.8 MiB/s) 7172119 bytes read in 308 ms (22.2 MiB/s) gpio: pin 115 (gpio 115) value is 1 ## Flattened Device Tree blob at 4fa00000   Booting using the fdt blob at 0x4fa00000   Loading Ramdisk to 49928000, end 49fff017 ... OK   Loading Device Tree to 0000000049918000, end 000000004992788d ... OK Starting kernel ... [    0.654863] SMCCC: SOC_ID: ARCH_SOC_ID(0) returned error: ffffffffffffffff [    3.328194] i2c i2c-1: mv64xxx: I2C bus locked, block: 1, time_left: 0 [    3.334783] Goodix-TS 1-005d: i2c test failed attempt 1: -110 [    5.408192] i2c i2c-1: mv64xxx: I2C bus locked, block: 1, time_left: 0 [    5.414744] Goodix-TS 1-005d: i2c test failed attempt 2: -110 [    5.448189] Goodix-TS 1-005d: I2C communication failure: -110 Starting version 247.3-1-arch ROOT_MNJRO: recovering journal ROOT_MNJRO: clean, 173247/1880480 files, 1344654/7515099 blocks [    9.003700] iio iio:device1: failed to read Who-Am-I register. [  11.067969] i2c i2c-1: mv64xxx: I2C bus locked, block: 1, time_left: 0 [  11.074678] anx7688 1-0028: tcpc i2c read failed at 0x0 (-110) [  13.120226] i2c i2c-1: mv64xxx: I2C bus locked, block: 1, time_left: 0 [  13.126902] anx7688 1-0028: tcpc i2c read failed at 0x1 (-110) Manjaro Linux 5.11.3-1-MANJARO-ARM (ttyS0) plasma-mobile login:
And with the SD inserted
DRAM: 3072 MiB Trying to boot from MMC1 NOTICE:  BL31: v2.2(release):v2.2-904-gf9ea3a629 NOTICE:  BL31: Built : 15:32:12, Apr  9 2020 NOTICE:  BL31: Detected Allwinner A64/H64/R18 SoC (1689) NOTICE:  BL31: Found U-Boot DTB at 0x4064410, model: PinePhone NOTICE:  PSCI: System suspend is unavailable U-Boot 2020.07 (Nov 08 2020 - 00:15:12 +0100) DRAM:  3 GiB MMC:  Device 'mmc@1c11000': seq 1 is in use by 'mmc@1c10000' mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1 Loading Environment from FAT... *** Warning - bad CRC, using default environment starting USB... No working controllers found Hit any key to stop autoboot:  0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot.scr 653 bytes read in 2 ms (318.4 KiB/s) ## Executing script at 4fc00000 gpio: pin 114 (gpio 114) value is 1 4275261 bytes read in 188 ms (21.7 MiB/s) Uncompressed size: 10170376 = 0x9B3008 36162 bytes read in 3 ms (11.5 MiB/s) 1078500 bytes read in 49 ms (21 MiB/s) ## Flattened Device Tree blob at 4fa00000   Booting using the fdt blob at 0x4fa00000   Loading Ramdisk to 49ef8000, end 49fff4e4 ... OK   Loading Device Tree to 0000000049eec000, end 0000000049ef7d41 ... OK Starting kernel ... / #
But nothing on the screen but the backlight. Clearly there's something up but I'm not a hardware guy,
Bump. Still getting a black screen. I just need to be able to diagnose if this is the screen or mainboard.
Maybe additional information. I have tried plugging the hub device into the phone while booting and am unable to get any kind of hdmi output.
(10-20-2025, 04:32 PM)Richy_T Wrote: Bump. Still getting a black screen. I just need to be able to diagnose if this is the screen or mainboard.
There was a few months when I daily drove the PinePhone that the battery would get over 100% charged and the phone would not turn on. I remember just giving phone about 20 minutes not on a charger and it would turn ON.
Maybe updating the OS would help. I remember this only happening for a few months between updates.
Hard to update the OS without any screen output, I would think. I've tried booting with different levels of battery charge FWIW.
From reading around more, it seems the Pinephone project is dead anyway. I'll probably just throw the whole lot up on ebay as parts only.
  Pinephone visibly losing power while plugged in Hiraghm 10 10,068 10-14-2026, 04:20 PM
Last Post: Flymoon
  Pinephone software Csanderson0313 3 2,101 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 88,978 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 27,035 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 9,116 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,828 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,500 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 3,135 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,517 11-18-2025, 03:07 PM
  Does PinePhone support long-term battery health optimization? roseblack 5 5,110 10-06-2025, 09:05 PM
