Keyboard not working PPP is support broken atm?
I did take off the keyboard because it repeatedly would not charge the PinePhone Pro battery. Perhaps a good quality shim would fix this, but my one try did not succeed.
Now it seems that higher voltage chargers will not work with keyboard charging. Switching to an older slower charger has made the keyboard useful.
I guess you mean higher current (amperage) / power (wattage)? The voltage (tension) should always be 5V, everything else will certainly not work.
What Ampere (current) or Watt (power) rating worked and what did not, so that we get an idea of what the maximum could be, approximately?
The fix was only temporary. I have retired the keyboard in favor of an XIT folding Bluetooth keyboard when it is needed.
  Keyboard availability? KaylaMarie81 9 6,556 08-04-2025, 08:37 PM
Last Post: Peter Gamma
  altg, alt, and fn are not working moriartyo 0 1,581 05-06-2025, 03:14 AM
Last Post: moriartyo
  The XIT bluetooth folding keyboard can work with the Pinephone Pro mburns 0 2,494 11-09-2023, 10:57 AM
Last Post: mburns
  Fixing the PinePhone Keyboard for the Linux Console mburns 0 2,731 09-02-2023, 07:48 AM
Last Post: mburns
  Keyboard charges, won't type - ERROR: I2C_RDWR failed: No such device or address jovval 0 2,814 07-10-2023, 08:11 AM
Last Post: jovval
Exclamation Wireless charger (QI) not working on PinePhone Pro zeroskyx 6 12,861 05-13-2022, 09:59 AM
Last Post: zeroskyx
Bug Keyboard Power Issues Merc 13 21,907 05-02-2022, 09:41 AM
Last Post: dgiffin
  Checking Keyboard Charging Status dgiffin 0 4,267 04-23-2022, 03:40 AM
Last Post: dgiffin
  Use keyboard case as virtual mouse EwigeBlumenkraft 1 5,874 03-24-2022, 05:22 AM
Last Post: magdesign
  Hardware keyboard top row keycodes problem cyrelk 2 6,370 03-03-2022, 03:01 AM
Last Post: cyrelk
