altg, alt, and fn are not working
the keyboard used to work, then suddenly for no reason (no updates, configuration changes, or physical damage) the altg, alt, and fn keys stopped working, namely, nothing happens when they are combined with regular keys. I tried setxkbmap -option lv3:ralt_switch and 'https://gitlab.com/postmarketOS/pmaports/-/merge_requests/3438 ', also disabled the kernel module, but nothing helped. If you hold down altg, alt, fn and 2/3/5, then 235 is entered, which means that the keys give a signal. I tried on the latest versions of arch/pmos linux sxmo/phosh
  Keyboard not working PPP is support broken atm? joshndroid 13 16,080 02-24-2024, 01:59 PM
Last Post: mburns
Exclamation Wireless charger (QI) not working on PinePhone Pro zeroskyx 6 12,650 05-13-2022, 09:59 AM
Last Post: zeroskyx
