Command lines to remove the Phosh UI
Can anyone help? Someone told me what they were once and I forgot.
I have the latest Mobian installed and Plasma Mobile ui as I prefer it, no mandatory running apps shortcuts on the drawer and it's just more appealing to the eye.
But I don't have a need to bloat down the system with two ui's.
I checked on my phosh mobian boot (which I need working so I can't test this for you) and the packages that turn up for apt list \*phosh\* are:
libiceoryx-phosh-config2
libiceoryx-phosh-dev
libiceoryx-phosh-roudi2
libiceoryx-phosh2
phosh
So I would start with "sudo apt remove phosh" and see where that gets me. If not, try listing all of the packages in one apt remove command. Any of these commands could break your install so use at your own risk and make sure you have another boot option first.
  The Mobian Phosh Experience mburns 1 4,029 11-18-2023, 08:21 AM
Last Post: crocspot
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 2,199 10-14-2023, 11:57 AM
Last Post: mburns
  The Phosh Web app vs Angelfish mburns 0 2,089 06-19-2023, 11:57 AM
Last Post: mburns
  Manjaro Phosh - Tiny Blue Indicator Light - Blinking ArchiMark 2 3,725 06-11-2023, 04:12 PM
Last Post: ArchiMark
  How do I tell Phosh that my app is mobile friendly? Barugon 5 7,346 06-05-2023, 09:24 PM
Last Post: Barugon
  Phosh Updating - Battery Charge Indicator - Jittery Settings - Display Usability ArchiMark 4 5,746 05-28-2023, 07:00 AM
  Making and receiving calls via command line Zotax 0 2,446 01-28-2023, 12:19 PM
Last Post: Zotax
  create backup of os on ppp Arch/Phosh fox95 2 4,350 10-19-2022, 12:49 AM
Last Post: fox95
  Latest Manjaro-Phosh and Arch-Phosh won't boot grinzie 6 10,044 07-01-2022, 02:01 PM
Last Post: Chief
  My Conky config file for Phosh lat 0 2,417 04-21-2022, 12:16 PM
Last Post: lat
