Keyboard not popping up on QT apps
My Pinephone broke and I switched to Droidian, but I don't think this is a Droidian-specific question. Forgive me if it turns out to be irrelevant.
Anyway, my on-screen keyboard works fine on most apps, but I installed both Nextcloud client and Chromium browser, and in both cases, focusing on a text field doesn't cause the keyboard to deploy. The common denominator here is that both of these apps use QT and not GTK, and I assume this is relevant.
Has any one had this issue, and if so, how did you resolve it?
No, Chromium does not use Qt. The Nextcloud client does.
I assume you use Phosh? You should be able to force the keyboard to pop up manually, see https://forum.pine64.org/showthread.php?tid=19045.
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,322 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 11,697 12-23-2025, 04:25 AM
  New Install, apps start but don't show up on screen?! RT3 2 3,552 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,570 01-15-2025, 08:08 PM
  icon keyboard chris_02 4 6,072 01-14-2025, 02:49 AM
  New keyboard issue sandspur 30 40,784 01-13-2025, 01:37 AM
  Keyboard keeps disappearing the moment it's touched jojuma 1 3,113 10-29-2023, 08:34 AM
Last Post: walter1950
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 4,258 07-07-2023, 03:29 AM
Last Post: jojuma
  Battery problem with a Pinephone keyboard and Mobian elode 2 5,758 12-22-2022, 07:10 PM
Last Post: acid andy
  Would creating a 2 row landscape keyboard be difficult? rp3 1 3,472 09-09-2022, 06:49 AM
Last Post: zetabeta
