Another Fan Question
Question
I recently purchased an 80mm Noctua NF-A8 ULN fan for the Rock NAS case along with a Noctua 2pin to 3pin adaptor. Fan is indeed 12v.
Plugging it in I get nothing...no fan movement at all. I'm using a recent version of Armbian if that matters.
I believe I see this device under /sys/class/hwmon/hwmon4/ since is see pwm1 as well as pwm1_enable.
cat /sys/class/hwmon/hwmon4/pwm1_enable
returns 1
/sys/class/hwmon/hwmon4$ cat /sys/class/hwmon/hwmon4/pwm1
returns 0
echo 255 | sudo tee /sys/class/hwmon/hwmon4/pwm1
still no fan response
to verify my adjustment but this still returns 0. Fan is motionless.
At this point i'm ready to give up and connect to the boards 12v out but I have questions there.
The original cable it comes with splits to 2 different SATA connection leads, leading me to believe this is not a conventional connection? This is for the CON15 DC out header.
the Noctua includes a big 4pin adapter but I'm not confident in what to order. I also didn't see anything relevant in the Pine store for accessories.
FYI I'm currently not running any SATA drives as I recently opted for NVMe (mostly due to availability).
any help please!!??
(02-02-2024, 08:32 AM)backwoodstech2 Wrote: I recently purchased an 80mm Noctua NF-A8 ULN fan for the Rock NAS case along with a Noctua 2pin to 3pin adaptor. Fan is indeed 12v.
returns 1
returns 0
any help please!!??
I also tried everything in this forum post as well as the pwm1 settings failed to apply (even with root) until this was completed:
echo disabled > /sys/devices/virtual/thermal/thermal_zone0/mode
Rockpro64 CPU fan (pine64.org) (also cross-posted here: fancontrol - pwm1 keeps resetting to 0 - Odroid N2/N2+/HC4 - Armbian Community Forums)
I was able to get the fan speed settings to apply  but fan remains unresponsive. I tried the fan in every pwm mode available.
OS is OMV7 (Debian Bookworm, Armbian variant; Kernel: Linux 6.1.63-current-rockchip64)
Information Question regarding odd startup behaviour Mff 0 3,941 12-03-2022, 03:18 PM
Last Post: Mff
  Considering buying and question on the PCIe slot MobileJAD 25 65,424 11-07-2019, 03:10 PM
Last Post: hmuller
  RK3399 question enip 6 12,945 07-20-2019, 05:00 AM
Last Post: stuartiannaylor
  Basic question on the Nas case of the rockPro Slam 1 5,446 01-23-2019, 08:04 AM
Last Post: Slam
  Performance issue/question bobdaroze 8 19,252 11-11-2018, 10:41 PM
Last Post: tuxd3v
  Rock64 OMV video question / same for RockPro64 I would assume RockPro64Newbie 0 17,986 08-19-2018, 04:11 AM
Last Post: RockPro64Newbie
  Dual SATA-II Interface Card question and NAS question RockPro64Newbie 5 10,790 08-17-2018, 10:58 PM
  Power Supply ordering question frewind 8 16,993 08-03-2018, 11:15 AM
Last Post: dkryder
