2nd NetBSD boot goes dark
NetBSD 10.1_RC1 boots fine from SD after Manjaro, but if I shut it down and then boot it again - two NetBSD sessions in a row - the second session goes to a black screen after the first green boot print page.  In at least one case I was able to log in, blind, so this seems to be entirely a display issue.  To get back, I have to pop the SD, boot to Manjaro , reseat the SD and restart.  I don't have to do anything in particular during the NetBSD session - just log in as root and shut down, and I've used up my NetBSD quota of 1.
I installed tow-boot on SPI, and that got around the problem - in effect tow-boot serves as the alternate session, I guess.  But when booted from tow-boot, neither OS can see my USB wifi, I suppose tow-boot was too interested in it as a boot device.  So until I sort that out, I'm back to popping the SD every time.
Not that tow-boot worked very reliably anyway.
The problem is the U-Boot that comes with Manjaru. It only wants to boot Manjaru. If you install the U-Boot that comes with NetBSD, you can boot NetBSD or Manjaru or anything else at any time.
I'm surprised tow-boot even worked!
:wq
As it happens, I did try out the NetBSD u-boot. I then removed the back of the case, to find that shorting SPI pin 6 to ground isn't so easy as presented in the pine64 wiki, now that there's a cover plate that would have to be pried off. Luckily, I found that Manjaro would sometimes boot from the eMMC if I held the power button down long enough, and from there I could zero the SPI device up to a point. So luckily I'm back where I started.
I don't know why the NetBSD rockpro64 u-boot didn't work, but it sure didn't. Possibly the device isn't adequately supported right now as something that can be dd'd to, and if I carted it over to Linux and flashcp'd it it would be fine. Or I could get myself into a situation where I have to take a chisel to the board, so ... I don't know, maybe not.
tow-boot was mainly just erratic - sometimes it couldn't boot the SD, but if you keep trying, it would get it eventually. Or it would freeze up. I'd be using it, if it didn't knock out the USB wifi device. It's ragged, but it can choose a boot device.
Anyway ... the black screen problem returned right away after I zeroed the SPI, which didn't fit the normal pattern since it was after a Manjaro session.
I don't think the RockPro one is compatible. I wouldn't flash it to SPI at all, but that's me. The one for the Pinebook Pro does work, and of all the ones I've tried it works the best. (I haven't tried tow-boot). It does look for the dtb file in a different place than where it comes in the distribution though, IIRC.
:wq
It seems like you're encountering a display issue with NetBSD 10.1_RC1 after booting it for the second time in a row from SD. While the system boots fine initially, subsequent boots result in a black screen after the first green boot print page.
This issue could be related to the display driver or configuration settings. Since you mentioned being able to log in blind, it suggests that the system is running but not displaying properly.
I sometimes lose wscons display (NetBSD 9.3). Something happens to the virtual console and nothing but console messages will display. Sometimes switching to a different virtual console and back works, sometimes it doesn't. I wonder if it's similar to what you're experiencing. (I have not tried the 10 RCs)
:wq
  NetBSD 1.0 runs down battery donn 13 12,069 11-15-2023, 04:05 PM
  Booting NetBSD untitled 12 19,310 08-30-2022, 01:23 AM
Last Post: untitled
  NetBSD on the Pinebook Pro in August 2022 - or not? KC9UDX 6 11,628 08-24-2022, 01:49 AM
  NetBSD and pinebook keyboard/trackpad firmware updater mrgtwentythree 5 17,615 05-16-2021, 07:37 PM
Last Post: mrgtwentythree
  NetBSD Der Geist der Maschine 76 171,752 05-16-2021, 02:43 PM
Music NetBSD and USB "sound cards" KC9UDX 2 10,578 05-07-2021, 12:11 PM
Last Post: elimark1
Question Issues Installing NetBSD on a PineBook Pro ReleaseTheGeese 14 28,853 01-31-2021, 11:20 AM
  NetBSD -Current binaries BronzeBeard 8 20,803 12-31-2020, 08:38 PM
Last Post: BronzeBeard
Thumbs Up My NetBSD on Pinebook Pro journey KC9UDX 11 28,840 12-06-2020, 08:26 PM
