Quartz64B eMMC boot failure
I installed DietPi from https://dietpi.com/downloads/images/Diet...orm.img.xz onto a 32GB SD card and it booted successfully. The system had a 32GB eMMC module installed so using the instructions found in https://dietpi.com/blog/?p=1236 I copied the running SD card image to the eMMC.
The system will not boot from the eMMC but gets a Kernel Panic. Inserting the SD card doesn't help. If I remove the eMMC module, I can boot from the SD card again.
Obviously, the method I used to copy the system from the SD card to the eMMC was wrong. First, I'd like to erase the eMMC module so I can get back to a running system with the eMMC installed. Second, I need better instructions on how to successfully install DietPi on eMMC.
I managed to get the eMMC partition deleted so now the system boots from the SD card (mmcblk0) and sees the eMMC (mmcblk1).
dietpi@DietPi:~$ lsblk NAME        MAJ:MIN RM  SIZE RO TYPE MOUNTPOINTS mtdblock0    31:0    0  16M  0 disk mmcblk0      179:0    0 29.8G  0 disk └─mmcblk0p1  179:1    0 29.8G  0 part / mmcblk1      179:32  0 29.1G  0 disk mmcblk1boot0 179:64  0    4M  1 disk mmcblk1boot1 179:96  0    4M  1 disk dietpi@DietPi:~$
Now I just need proper instructions on how to install DietPi (or any other OS) on the eMMC.
(11-14-2023, 04:52 PM)bsmorgan Wrote:  (or any other OS) on the eMMC.
https://forum.pine64.org/showthread.php?...#pid108174
  No boot...power light shows green 98cwitr 2 6,371 01-19-2024, 07:31 PM
Last Post: Darin755
  Need a working image for Quartz64B Excalibur 23 34,191 02-24-2023, 12:11 AM
Last Post: balbes150
  PXE/iSCSI Boot jg159357 1 5,320 07-31-2022, 06:45 AM
Last Post: vincele
  Quartz64 Model-A 8GB board boot error d4s 6 13,422 01-25-2022, 08:32 AM
Last Post: d4s
  can quartz64 boot without blobs greentree 1 4,272 01-08-2022, 11:56 PM
Last Post: CounterPillow
