PinePhone. How to run Python/Tkinter app?
Hello everyone
I have a problem.
A two years ago I created an application for Raspberry Pi 3 in Python and Tkinter.
Recently I bought a PinePhone64 and I would like to transfer this application to this device. I installed Mobian with Phosh there.
After researching the subject, it turned out that the RPi has an X11 display server, and the PP64 has a wayland.
Is there any possibility to run my application on PP64 without rebuilding the GUI?
How to do it?
I tried to install X11 server.
sudo apt install xauth xorg
later
sudo startx
Server starts, but the interface on the device changes to this:
[Image: 008946351-.html#1]
https://zdjecianaallegro.pl/gallery/008946351-.html#1
The touch does not work, the keyboard cannot be brought up.
I would like my application to appear in the original interface.
[Image: 008946351-2.html#2]
https://zdjecianaallegro.pl/gallery/008946351-2.html#2
I am a beginner in Mobian & Linux
Thank you in advance for your help
Running a standalone X11 session is a bad idea on the PinePhone. Phosh does not support it (and neither does Plasma Mobile). There is SXMO which supports X11, but since you write you are a beginner to GNU/Linux, I doubt you will want to use that (and I also think it is not supported by Mobian).
Instead, you will want to use XWayland (apt install xwayland) in the Wayland session. (You should not have to do anything beyond installing the package. It should get autostarted if it is installed.)
(08-23-2023, 05:09 PM)Kevin Kofler Wrote: Running a standalone X11 session is a bad idea on the PinePhone. Phosh does not support it (and neither does Plasma Mobile). There is SXMO which supports X11, but since you write you are a beginner to GNU/Linux, I doubt you will want to use that (and I also think it is not supported by Mobian).
I did
sudo apt update sudo apt upgrade sudo apt install xwayland
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
xwayland is already the newest version (2:23.2.0-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
How can I now use XWayland to run a python program?
Thumbs Up
It worked!!!
DISPLAY=:1 python3 app.py
So easy...
  Pinephone visibly losing power while plugged in Hiraghm 10 10,394 10-14-2026, 04:20 PM
Last Post: Flymoon
  Pinephone software Csanderson0313 3 2,183 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 89,401 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 27,285 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 9,282 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,880 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,582 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 3,209 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,605 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 9,079 10-21-2025, 12:12 PM
Last Post: Richy_T
