Quartz64 model a neither booting nor resetting without pressing reset button
Hi all, i just installed two quartz64 model a sbc, i choose manjaro arm and it runs pretty well , the only thing that fails is that, to boot the board, it needs to mantain the reset button pressed while connecting the dc power jack, after a while it loads the os.
If not doing so it doesn't boot. So i cannot reboot the board remotely (so it cannot be ran as remote server)
I am using a 64GB sandisk extreme sd (model SDSQXAH-064G-GN6MA ). I have ordered a kingston  CANVAS GO PLUS to check if things get better. Also i am thinking if an emmc module will be better, so maybe i'll get a okdo emmc module ( https://es.rs-online.com/web/p/complemen...ck/2565008 ).
What do you think? Has anyone this same boot problems?
Thanks !
An eMMC module should be (a lot) faster, but I doubt it'll have an effect on your issue. Better double check whether the eMMC module you linked *can* be used on a Quartz64 (at all). AFAIK all Pine64 devices use the same type of eMMC module, with the same type of connector, but AFAIK you can't just use some random eMMC module.
Try to boot with Plebian to see whether it's a hardware or software (ie Manjaro) issue
(08-23-2023, 09:48 AM)diederik Wrote: An eMMC module should be (a lot) faster, but I doubt it'll have an effect on your issue. Better double check whether the eMMC module you linked *can* be used on a Quartz64 (at all). AFAIK all Pine64 devices use the same type of eMMC module, with the same type of connector, but AFAIK you can't just use some random eMMC module.
Thank0s for helping @diederik ,
I have a working emmc from radxa https://es.rs-online.com/web/p/complemen...ck/2565008
I just tested plebian and it's the same... here the output
[font=monospace][color=#000000][[/color][color=#18b218]  OK  [/color][color=#000000]] Reached target [/color][color=#000000][b]reboot.target[/b][/color][color=#000000] - System Reboot. [/color] [   76.560603] watchdog: watchdog0: watchdog did not stop! [   76.693402] systemd-shutdown[1]: Using hardware watchdog 'Synopsys DesignWare Watchdog', version 0, device /dev/watch dog0 [   76.694485] systemd-shutdown[1]: Watchdog running with a timeout of 10min. [   77.052649] systemd-shutdown[1]: Syncing filesystems and block devices. [   77.405448] systemd-shutdown[1]: Sending SIGTERM to remaining processes... [   77.441987] systemd-journald[283]: Received SIGTERM from PID 1 (systemd-shutdow). [   77.508325] systemd-shutdown[1]: Sending SIGKILL to remaining processes... [   77.548703] systemd-shutdown[1]: Unmounting file systems. [   77.554302] (sd-remount)[594]: Remounting '/' read-only with options ''. [   77.570115] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none. [   77.578547] systemd-shutdown[1]: All filesystems unmounted. [   77.579129] systemd-shutdown[1]: Deactivating swaps. [   77.579914] systemd-shutdown[1]: All swaps deactivated. [   77.580430] systemd-shutdown[1]: Detaching loop devices. [   77.588292] systemd-shutdown[1]: All loop devices detached. [   77.588888] systemd-shutdown[1]: Stopping MD devices. [   77.590095] systemd-shutdown[1]: All MD devices stopped. [   77.590620] systemd-shutdown[1]: Detaching DM devices. [   77.591771] systemd-shutdown[1]: All DM devices detached. [   77.592306] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached. [   77.594555] watchdog: watchdog0: watchdog did not stop! [   77.610791] systemd-shutdown[1]: Syncing filesystems and block devices. [   77.615010] systemd-shutdown[1]: Rebooting. [   77.615489] kvm: exiting hardware virtualization [   77.661798] reboot: Restarting system DDR Version V1.13 20220218 ln ddrconfig:7 LPDDR4X, 324MHz BW=32 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=8192MB tdqss: cs0 dqs0: 96ps, dqs1: -120ps, dqs2: -72ps, dqs3: -144ps,   tdqss: cs1 dqs0: 72ps, dqs1: -120ps, dqs2: -96ps, dqs3: -120ps,   change to: 324MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x60 change to: 528MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x80 change to: 780MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x80 change to: 1056MHz(final freq) PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:22% dram drv:40,odt:80 vref_ca:00000071 clk skew:0x80 cs 0: the read training result: DQS0:0x50, DQS1:0x50, DQS2:0x51, DQS3:0x4e,   min  : 0x9  0xc  0xd  0xd  0x1  0x3  0x5  0x5 , 0x4  0x8  0x1  0x1  0xb  0xa  0xc  0x8 ,       0xf  0xf  0xe  0xa  0x5  0x6  0x2  0x6 , 0xb  0x5  0x5  0x2  0x9  0xb  0x7  0xc , mid  :0x30 0x31 0x32 0x31 0x27 0x28 0x2b 0x29 ,0x27 0x2a 0x23 0x24 0x2c 0x2d 0x2e 0x2c ,      0x32 0x30 0x2e 0x2f 0x27 0x27 0x24 0x2b ,0x2e 0x28 0x28 0x26 0x2b 0x31 0x2a 0x30 , max  :0x58 0x56 0x58 0x55 0x4d 0x4e 0x52 0x4e ,0x4a 0x4c 0x46 0x47 0x4e 0x51 0x50 0x50 ,      0x55 0x51 0x4f 0x54 0x4a 0x49 0x46 0x50 ,0x51 0x4c 0x4b 0x4b 0x4e 0x57 0x4e 0x54 , range:0x4f 0x4a 0x4b 0x48 0x4c 0x4b 0x4d 0x49 ,0x46 0x44 0x45 0x46 0x43 0x47 0x44 0x48 ,      0x46 0x42 0x41 0x4a 0x45 0x43 0x44 0x4a ,0x46 0x47 0x46 0x49 0x45 0x4c 0x47 0x48 , the write training result: DQS0:0x80, DQS1:0x80, DQS2:0x80, DQS3:0x80,   min  :0x95 0x97 0x99 0x96 0x90 0x91 0x93 0x94 0x93 ,0x87 0x88 0x85 0x83 0x8a 0x8b 0x8d 0x8c 0x88 ,      0x8b 0x8b 0x88 0x88 0x85 0x82 0x84 0x87 0x86 ,0x88 0x87 0x87 0x84 0x8b 0x8c 0x8b 0x8f 0x88 , mid  :0xb3 0xb5 0xb6 0xb3 0xac 0xae 0xb0 0xb0 0xaf ,0xa4 0xa4 0xa2 0xa1 0xa6 0xa7 0xa8 0xa8 0xa5 ,      0xa9 0xa8 0xa5 0xa5 0xa2 0x9f 0xa1 0xa3 0xa3 ,0xa6 0xa4 0xa3 0xa1 0xa8 0xa9 0xa6 0xab 0xa4 , max  :0xd1 0xd3 0xd4 0xd1 0xc8 0xcb 0xcd 0xcc 0xcb ,0xc2 0xc1 0xbf 0xbf 0xc3 0xc3 0xc3 0xc4 0xc2 ,      0xc7 0xc6 0xc2 0xc3 0xbf 0xbd 0xbe 0xbf 0xc1 ,0xc5 0xc1 0xc0 0xbf 0xc5 0xc6 0xc2 0xc7 0xc1 , range:0x3c 0x3c 0x3b 0x3b 0x38 0x3a 0x3a 0x38 0x38 ,0x3b 0x39 0x3a 0x3c 0x39 0x38 0x36 0x38 0x3a ,      0x3c 0x3b 0x3a 0x3b 0x3a 0x3b 0x3a 0x38 0x3b ,0x3d 0x3a 0x39 0x3b 0x3a 0x3a 0x37 0x38 0x39 , cs 1: the read training result: DQS0:0x3a, DQS1:0x39, DQS2:0x3c, DQS3:0x36,   min  : 0xb  0xb  0xd  0xc  0x1  0x3  0x6  0x3 , 0x7  0x7  0x2  0x1  0xb  0xa  0xe  0x9 ,       0xf  0xe  0xb  0xa  0x4  0x1  0x2  0x5 , 0x9  0x6  0x5  0x1  0xd  0xb  0x9  0xb , mid  :0x28 0x29 0x2b 0x29 0x1d 0x20 0x23 0x1f ,0x23 0x24 0x20 0x1f 0x28 0x27 0x2a 0x26 ,      0x2b 0x2a 0x27 0x25 0x21 0x1e 0x1e 0x21 ,0x26 0x22 0x22 0x1d 0x28 0x28 0x26 0x28 , max  :0x45 0x47 0x49 0x47 0x3a 0x3e 0x40 0x3c ,0x40 0x42 0x3e 0x3d 0x45 0x45 0x47 0x44 ,      0x48 0x47 0x43 0x41 0x3f 0x3b 0x3a 0x3d ,0x44 0x3f 0x3f 0x39 0x44 0x46 0x43 0x46 , range:0x3a 0x3c 0x3c 0x3b 0x39 0x3b 0x3a 0x39 ,0x39 0x3b 0x3c 0x3c 0x3a 0x3b 0x39 0x3b ,      0x39 0x39 0x38 0x37 0x3b 0x3a 0x38 0x38 ,0x3b 0x39 0x3a 0x38 0x37 0x3b 0x3a 0x3b , the write training result: DQS0:0x80, DQS1:0x80, DQS2:0x80, DQS3:0x80,   min  :0xb0 0xb4 0xb4 0xb1 0xa5 0xa9 0xac 0xad 0xac ,0x95 0x95 0x90 0x90 0x99 0x9a 0x9b 0x9b 0x97 ,      0x9d 0x9c 0x98 0x99 0x93 0x8f 0x91 0x96 0x96 ,0x9a 0x98 0x95 0x92 0x9c 0x9c 0x9b 0x9f 0x96 , mid  :0xcc 0xce 0xce 0xcc 0xbf 0xc3 0xc7 0xc7 0xc5 ,0xb2 0xb1 0xab 0xaa 0xb4 0xb3 0xb4 0xb4 0xb0 ,      0xb8 0xb7 0xb3 0xb3 0xac 0xa6 0xa9 0xae 0xaf ,0xb5 0xb2 0xae 0xab 0xb5 0xb8 0xb1 0xba 0xae , max  :0xe8 0xe9 0xe9 0xe7 0xda 0xdd 0xe2 0xe1 0xdf ,0xcf 0xcd 0xc7 0xc5 0xd0 0xcd 0xcd 0xcd 0xc9 ,      0xd4 0xd3 0xce 0xcd 0xc6 0xbd 0xc1 0xc6 0xc8 ,0xd1 0xcc 0xc7 0xc5 0xcf 0xd4 0xc7 0xd5 0xc7 , range:0x38 0x35 0x35 0x36 0x35 0x34 0x36 0x34 0x33 ,0x3a 0x38 0x37 0x35 0x37 0x33 0x32 0x32 0x32 ,      0x37 0x37 0x36 0x34 0x33 0x2e 0x30 0x30 0x32 ,0x37 0x34 0x32 0x33 0x33 0x38 0x2c 0x36 0x31 , CA Training result: cs:0 min  :0x50 0x55 0x46 0x45 0x47 0x43 0x4d , 0x0 0x4c 0x42 0x47 0x40 0x44 0x89 , cs:0 mid  :0x8f 0x92 0x84 0x83 0x84 0x82 0x7d , 0x0 0x88 0x82 0x82 0x82 0x7f 0x88 , cs:0 max  :0xce 0xd0 0xc3 0xc1 0xc2 0xc1 0xae , 0x0 0xc4 0xc3 0xbd 0xc4 0xbb 0x87 , cs:0 range:0x7e 0x7b 0x7d 0x7c 0x7b 0x7e 0x61 , 0x0 0x78 0x81 0x76 0x84 0x77 0xfffffffe , cs:1 min  :0x4e 0x55 0x3f 0x47 0x42 0x45 0x4a ,0x48 0x4d 0x42 0x46 0x41 0x43 0x47 , cs:1 mid  :0x8f 0x90 0x82 0x83 0x84 0x80 0x7b ,0x8a 0x88 0x83 0x81 0x82 0x7f 0x79 , cs:1 max  :0xd0 0xcb 0xc5 0xbf 0xc6 0xbc 0xad ,0xcc 0xc4 0xc4 0xbd 0xc3 0xbb 0xab , cs:1 range:0x82 0x76 0x86 0x78 0x84 0x77 0x63 ,0x84 0x77 0x82 0x77 0x82 0x78 0x64 , out DDR V1.16 6f71c736ce typ 23/03/02-20:01:48 ln LP4/4x derate en, other dram:1x trefi ddrconfig:7 LPDDR4X, 324MHz BW=32 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=8192MB tdqss: cs0 dqs0: 96ps, dqs1: -120ps, dqs2: -72ps, dqs3: -144ps,   tdqss: cs1 dqs0: 72ps, dqs1: -120ps, dqs2: -96ps, dqs3: -144ps,   change to: 324MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x60 change to: 528MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x80 change to: 780MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x80 change to: 1056MHz(final freq) PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:22% dram drv:40,odt:80 vref_ca:00000071 clk skew:0x80 cs 0: the read training result: DQS0:0x51, DQS1:0x53, DQS2:0x53, DQS3:0x4d,   min  : 0xc  0xd  0xe  0xd  0x2  0x3  0x6  0x5 , 0x7  0x8  0x3  0x2  0xf  0xb 0x10  0x9 ,      0x10 0x10  0xe  0xa  0x5  0x4  0x1  0x6 , 0xb  0x5  0x5  0x2  0xa  0xc  0x6  0xa , mid  :0x34 0x34 0x36 0x34 0x2a 0x2b 0x2e 0x2c ,0x2e 0x2f 0x2a 0x28 0x35 0x32 0x36 0x31 ,      0x37 0x36 0x33 0x32 0x2c 0x2a 0x28 0x2e ,0x32 0x2c 0x2c 0x29 0x30 0x34 0x2d 0x32 , max  :0x5c 0x5c 0x5e 0x5b 0x53 0x54 0x57 0x54 ,0x56 0x57 0x52 0x4f 0x5b 0x5a 0x5d 0x59 ,      0x5e 0x5c 0x59 0x5b 0x53 0x51 0x50 0x57 ,0x59 0x54 0x53 0x51 0x56 0x5c 0x55 0x5a , range:0x50 0x4f 0x50 0x4e 0x51 0x51 0x51 0x4f ,0x4f 0x4f 0x4f 0x4d 0x4c 0x4f 0x4d 0x50 ,      0x4e 0x4c 0x4b 0x51 0x4e 0x4d 0x4f 0x51 ,0x4e 0x4f 0x4e 0x4f 0x4c 0x50 0x4f 0x50 , the write training result: DQS0:0x80, DQS1:0x80, DQS2:0x80, DQS3:0x80,   min  :0x95 0x98 0x99 0x97 0x90 0x91 0x93 0x95 0x94 ,0x86 0x88 0x85 0x83 0x8a 0x8b 0x8d 0x8c 0x88 ,      0x8b 0x8c 0x88 0x88 0x85 0x82 0x84 0x87 0x86 ,0x86 0x85 0x84 0x81 0x88 0x89 0x88 0x8c 0x85 , mid  :0xb3 0xb5 0xb6 0xb4 0xac 0xae 0xb0 0xb0 0xaf ,0xa4 0xa4 0xa2 0xa1 0xa6 0xa6 0xa8 0xa8 0xa5 ,      0xa9 0xa9 0xa5 0xa5 0xa2 0x9f 0xa1 0xa3 0xa3 ,0xa4 0xa2 0xa1 0x9f 0xa5 0xa5 0xa4 0xa8 0xa2 , max  :0xd1 0xd3 0xd4 0xd2 0xc8 0xcb 0xcd 0xcc 0xcb ,0xc2 0xc1 0xbf 0xbf 0xc3 0xc2 0xc3 0xc4 0xc2 ,      0xc8 0xc7 0xc2 0xc3 0xbf 0xbd 0xbe 0xbf 0xc0 ,0xc2 0xbf 0xbf 0xbe 0xc2 0xc2 0xc0 0xc5 0xbf , range:0x3c 0x3b 0x3b 0x3b 0x38 0x3a 0x3a 0x37 0x37 ,0x3c 0x39 0x3a 0x3c 0x39 0x37 0x36 0x38 0x3a ,      0x3d 0x3b 0x3a 0x3b 0x3a 0x3b 0x3a 0x38 0x3a ,0x3c 0x3a 0x3b 0x3d 0x3a 0x39 0x38 0x39 0x3a , cs 1: the read training result: DQS0:0x3b, DQS1:0x3a, DQS2:0x3d, DQS3:0x37,   min  : 0xc  0xd 0x10  0xd  0x1  0x4  0x6  0x3 , 0x7  0x7  0x3  0x1  0xb  0xa  0xe  0x8 ,      0x10  0xf  0xd  0xa  0x6  0x2  0x2  0x5 , 0x9  0x5  0x4  0x1  0xd  0xd  0x9  0xd , mid  :0x2a 0x2b 0x2e 0x2b 0x1f 0x22 0x24 0x21 ,0x25 0x26 0x21 0x1f 0x2a 0x28 0x2c 0x27 ,      0x2d 0x2c 0x29 0x27 0x23 0x1f 0x1f 0x22 ,0x27 0x23 0x22 0x1f 0x2a 0x2a 0x27 0x2a , max  :0x49 0x49 0x4c 0x49 0x3e 0x40 0x42 0x40 ,0x44 0x45 0x40 0x3e 0x49 0x47 0x4b 0x46 ,      0x4a 0x49 0x46 0x44 0x40 0x3d 0x3d 0x40 ,0x46 0x42 0x41 0x3d 0x48 0x48 0x46 0x48 , range:0x3d 0x3c 0x3c 0x3c 0x3d 0x3c 0x3c 0x3d ,0x3d 0x3e 0x3d 0x3d 0x3e 0x3d 0x3d 0x3e ,      0x3a 0x3a 0x39 0x3a 0x3a 0x3b 0x3b 0x3b ,0x3d 0x3d 0x3d 0x3c 0x3b 0x3b 0x3d 0x3b , the write training result: DQS0:0x80, DQS1:0x80, DQS2:0x80, DQS3:0x80,   min  :0xaf 0xb3 0xb4 0xb1 0xa5 0xa8 0xab 0xac 0xab ,0x94 0x94 0x90 0x90 0x97 0x98 0x99 0x99 0x94 ,      0x9d 0x9b 0x98 0x98 0x92 0x8f 0x90 0x96 0x95 ,0x96 0x93 0x91 0x8f 0x97 0x97 0x96 0x9b 0x91 , mid  :0xcc 0xce 0xcf 0xcc 0xc0 0xc4 0xc7 0xc7 0xc6 ,0xb1 0xb1 0xac 0xab 0xb4 0xb4 0xb4 0xb4 0xb0 ,      0xb9 0xb7 0xb3 0xb3 0xad 0xa8 0xaa 0xaf 0xaf ,0xb2 0xaf 0xac 0xaa 0xb2 0xb3 0xae 0xb6 0xac , max  :0xe9 0xea 0xea 0xe8 0xdc 0xe0 0xe4 0xe2 0xe2 ,0xcf 0xce 0xc9 0xc7 0xd1 0xd0 0xd0 0xd0 0xcd ,      0xd5 0xd4 0xcf 0xce 0xc8 0xc2 0xc4 0xc8 0xc9 ,0xce 0xcb 0xc8 0xc5 0xcd 0xd0 0xc7 0xd2 0xc7 , range:0x3a 0x37 0x36 0x37 0x37 0x38 0x39 0x36 0x37 ,0x3b 0x3a 0x39 0x37 0x3a 0x38 0x37 0x37 0x39 ,      0x38 0x39 0x37 0x36 0x36 0x33 0x34 0x32 0x34 ,0x38 0x38 0x37 0x36 0x36 0x39 0x31 0x37 0x36 , CA Training result: cs:0 min  :0x53 0x53 0x49 0x42 0x49 0x40 0x4d , 0x0 0x4b 0x43 0x46 0x42 0x43 0x8a , cs:0 mid  :0x8f 0x93 0x84 0x83 0x84 0x82 0x7c , 0x0 0x88 0x82 0x82 0x82 0x80 0x89 , cs:0 max  :0xcb 0xd4 0xc0 0xc5 0xc0 0xc5 0xac , 0x0 0xc6 0xc2 0xbf 0xc3 0xbd 0x88 , cs:0 range:0x78 0x81 0x77 0x83 0x77 0x85 0x5f , 0x0 0x7b 0x7f 0x79 0x81 0x7a 0xfffffffe , cs:1 min  :0x51 0x54 0x42 0x46 0x44 0x44 0x49 ,0x49 0x4c 0x43 0x45 0x42 0x42 0x46 , cs:1 mid  :0x90 0x90 0x83 0x83 0x84 0x80 0x7a ,0x8a 0x88 0x83 0x82 0x82 0x7f 0x78 , cs:1 max  :0xcf 0xcd 0xc4 0xc1 0xc4 0xbd 0xac ,0xcb 0xc5 0xc3 0xbf 0xc2 0xbd 0xaa , cs:1 range:0x7e 0x79 0x82 0x7b 0x80 0x79 0x63 ,0x82 0x79 0x80 0x7a 0x80 0x7b 0x64 , out [/font]
In other quartz64 a board, plebian reboot command works as it should...
  The "Should I buy a Quartz64 right now?" flow chart CounterPillow 5 23,933 05-05-2026, 07:57 AM
Last Post: kapqa
  Quartz64 seeming died Darin755 0 2,401 01-19-2024, 07:29 PM
Last Post: Darin755
  Thoughts on repairs for a Quartz64-B beepy 1 4,251 08-02-2023, 05:02 PM
Last Post: beepy
Question Li-Pol QUARTZ64 Model-B vs Model-A polrus 1 4,537 07-13-2023, 10:36 PM
  can't get quartz64-A working jyoung 14 20,603 04-29-2023, 04:41 PM
Last Post: diederik
  Trustzone support for QUARTZ64 capablegh 13 24,902 04-28-2023, 01:58 AM
Last Post: NCLI
  Booting Quartz64 Model B Jojo120120 14 22,516 01-23-2023, 03:31 AM
Last Post: balbes150
  quartz64 model b 2x20 max power proj964 1 5,203 10-23-2022, 05:32 AM
Last Post: CounterPillow
  quartz64 model b 2x20 pin header proj964 1 5,263 10-23-2022, 05:21 AM
  JTAG/SWD on Quartz64 model A capablegh 4 11,709 10-03-2022, 03:16 PM
Last Post: fatalfeel
