pinetab 2 not booting
Iv'e got my pine tab 2 to boot once again and the only thing it says is [    0.000000] clk: failed to reparent gpll to clk_rtc32k_frac: -22 it repeats this line 1 more time and below both lines I get a flashing cursor  does anybody out there know what it means? and what do I need to do to get it run again? please thisis driving me nuts pine64 insists that the community will help please!
No idea. Did you try asking the devs on Discord?
(07-13-2023, 05:09 PM)ajhiii070 Wrote: Iv'e got my pine tab 2 to boot once again and the only thing it says is [    0.000000] clk: failed to reparent gpll to clk_rtc32k_frac: -22 it repeats this line 1 more time and below both lines I get a flashing cursor  does anybody out there know what it means? and what do I need to do to get it run again? please thisis driving me nuts pine64 insists that the community will help please!
I have this error message as well plus some more but the PineTab2 is booting fine into the original Archlinux.
My guess is that your Linux is not starting and I think I remember that there were a few cases before and the advice was to reinstall the original factory image.
You find some instructions in the Wiki how to do that with the UART adapter that was part of the delivery (in the package with the power cable)
If you have more questions you can also join the chat, I recommend a matrix client (Element) because then you can search the chat.
(07-14-2023, 06:14 AM)Surehand53 It is gone again  there is no way to install a new image as it is not seen on any of my computers at this point it doesn't even turn on it is going back monday it hasn't worked correctly since it was delivered I'm over it and will move on to something else that will work as it's supposed to it wasn't ready for release and still isn't no wifi or bluetooth or cameras as I said I'm over it! Wrote:
Please translate in short simple sentences/Пожалуйста, переводите короткими простыми предложениями.
PinePhone, Pinebook Pro & PineTab2 owner.
For those who might find this.
To me the problem was that device battery was drained when plugged to power all worked again.
Chat GPT explained me that "the message "failed to reparent gpll" usually pertains to a warning related to the Graphics Phase-Locked Loop (GPLL) or another PLL on certain ARM chips during the boot process." Apparently this is just a warning but not the problem.
Check out discord for debug if problem still there (https://discord.gg/wmeb8687)
  Pinetab-V boot rescue anoduck 2 1,463 10-21-2025, 12:58 AM
Last Post: anoduck
  Any updates on Bluetooth for PineTab 2? BluetoothBroke 1 2,045 08-05-2025, 06:38 AM
  Bricked Pinetab 2 vatin 6 4,881 06-06-2025, 08:46 AM
Last Post: maxaltepo
  Gentoo on Pinetab istewart 0 1,929 01-26-2025, 08:21 PM
Last Post: istewart
  Pinetab-V Upgrade WrVLink 0 2,081 12-14-2024, 02:30 AM
Last Post: WrVLink
  PineTab Bluetooth PimpDiCaprio 5 6,073 11-02-2024, 11:46 AM
  Pinetab 2 just arrived + when can hope to se wifi driver LRP 15 22,168 02-28-2024, 05:03 AM
Last Post: Surehand53
Wink Screen protector for PineTab 2 vatin 0 2,766 11-18-2023, 01:31 AM
Last Post: vatin
  PineTab 2 (arm64) thoughts and questions acruhl 7 10,092 09-01-2023, 01:13 PM
Last Post: acruhl
  Booting from SD card on Pinetab2 samochimaaron 10 12,391 08-23-2023, 09:38 AM
Last Post: diederik
