Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159
Hello
when I try to install the Driver CH341SER from CH341SER_LINUX.ZIP - 南京沁恒微电子股份有限公司 (wch.cn) for the Ayufan linux build. I get this error Message during the compilation:
rock64@rockpro64:~/CH341SER_LINUX/driver$ make make -C /lib/modules/4.4.190-1233-rockchip-ayufan-gd3f1be0ed310/build  M=/home/rock64/CH341SER_LINUX/driver  make[1]: Entering directory '/usr/src/linux-headers-4.4.190-1233-rockchip-ayufan-gd3f1be0ed310'   CC [M]  /home/rock64/CH341SER_LINUX/driver/ch341.o gcc: error: unrecognized command line option '-mgeneral-regs-only' gcc: error: unrecognized command line option '-mcmodel=large' scripts/Makefile.build:283: recipe for target '/home/rock64/CH341SER_LINUX/driver/ch341.o' failed make[2]: *** [/home/rock64/CH341SER_LINUX/driver/ch341.o] Error 1 Makefile:1479: recipe for target '_module_/home/rock64/CH341SER_LINUX/driver' failed make[1]: *** [_module_/home/rock64/CH341SER_LINUX/driver] Error 2 make[1]: Leaving directory '/usr/src/linux-headers-4.4.190-1233-rockchip-ayufan-gd3f1be0ed310' Makefile:5: recipe for target 'default' failed make: *** [default] Error 2
I want to use the PineDisplay as Display on Linux and since Ayufan has a Documentation how to use it on his Linux Build, i use it.
But i need to install the Driver to use a CH340c RS485 to USB converter.
Any help is greatly appreciated.
What version of gcc you are using? Your gcc doesn't understand the two commandline options '-mgeneral-regs-only' and '-mcmodel=large'
I'm on 6.0.0-1164-ayufan and compiling with gcc 13.1.1 that driver works like a charm:
$ make make -C /lib/modules/6.0.0-1164-ayufan-ga2fd0c498/build M=/tmp/CH341SER_LINUX/driver make[1]: Entering directory '/usr/src/linux-headers-6.0.0-1164-ayufan-ga2fd0c498' warning: the compiler differs from the one used to build the kernel The kernel was built by: aarch64-linux-gnu-gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0 You are using: aarch64-alt-linux-gcc (GCC) 13.1.1 20230613 (ALT Sisyphus 13.1.1-alt1) CC [M] /tmp/CH341SER_LINUX/driver/ch341.o MODPOST /tmp/CH341SER_LINUX/driver/Module.symvers CC [M] /tmp/CH341SER_LINUX/driver/ch341.mod.o LD [M] /tmp/CH341SER_LINUX/driver/ch341.ko make[1]: Leaving directory '/usr/src/linux-headers-6.0.0-1164-ayufan-ga2fd0c498'
That driver loads into that kernel without complaint:
[ 152.041600] ch341: loading out-of-tree module taints kernel.
[ 152.042335] usbcore: registered new interface driver usb_ch341
[ 152.042341] ch341: USB serial driver for ch340, ch341, etc.
[ 152.042344] ch341: V1.6 On 2022.08
May be is is incompatible with the legacy kernel?
I choose the Version, because it is marked as the latest stable build, but I'll try updating the Compiler if you think that would solve the Problem.
I still get the same error after updating gcc to gcc-9 following this tutorial: How to Install GCC Compiler on Ubuntu 18.04 | Linuxize
(07-12-2023, 01:14 AM)Thisone Wrote: I still get the same error after updating gcc to gcc-9 following this tutorial: How to Install GCC Compiler on Ubuntu 18.04 | Linuxize
I don't know about "latest stable build." You are just using a lot of legacy software. Kernel 4.4 is legacy, gcc-9 is legacy. Try to use an older version of your driver that fits into that environment. For example https://github.com/juliagoda/CH341SER/tree/ubuntu
There is also a CH341-driver allready included into 4.4. The README.md of the vendor-driver states, that this driver is too old. I think the vendor has adapted the driver to modern gcc/kernel versions, because x86_64 is not holding back at 4.4. That often breaks compatibility to older versions.
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 22,581 09-27-2026, 11:42 AM
  Installing Ubuntu Server on RockPro64 deutschlmao 2 10,181 10-29-2023, 04:43 PM
Last Post: brotherj4mes
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 6,120 09-22-2023, 04:27 AM
Last Post: diederik
  GPIO on Ayufan 0.9.14 Build Thisone 7 9,768 04-23-2023, 01:32 PM
Last Post: diederik
  Linux laptop does not detect the board when plugged in via USB soupy 1 7,859 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 4,136 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  RockPro64 linux console video mode callegar 0 2,924 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 18,322 04-30-2022, 03:57 PM
Last Post: TRS-80
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 11,793 01-03-2022, 10:32 AM
Last Post: whitecat23
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 3,388 07-24-2021, 09:46 PM
Last Post: Mentaluproar
