is it possible to install a pinephone pro mainboard in a pinephone
i would like to know if it is possible to install a pinephone pro mainboard in a pinephone for an upgrade of the cpu, ram and storage
(01-22-2023, 01:09 PM)hannescam Wrote: i would like to know if it is possible to install a pinephone pro mainboard in a pinephone for an upgrade of the cpu, ram and storage
That is not possible, the parts are incompatible.
You will find your answer in Pinephone Pro's webpage here.
Specifically
Quote:I am a PinePhone owner – will I be able to upgrade it by installing a PinePhone Pro mainboard?
Probably not. While the PinePhone Pro’s mainboard will fit the PinePhone, the chassis, IPS display panel, cameras, the daughterboard, and thermal dissipation systems are all different. For instance, the PinePhone Pro’s cameras will not fit into the PinePhone chassis and are electrically incompatible with the PinePhone’s mainboard. Software enablement would also be required to drive the original PinePhone’s components (such as the LCD) using the PinePhone Pro’s mainboard. Thermal dissipation is another important consideration, as the higher heat output may not be trivial to overcome in the original PinePhone’s chassis.
thankyou for your answer
Specifically
Don't the wiki state the pine phone as using the same screen as the pro?
(07-10-2023, 10:11 AM)brken Wrote: Don't the wiki state the pine phone as using the same screen as the pro?
PinePhone and PinePhone Pro using different LCD panel.
The answer is actually a 'lil bit more nuanced than "No, they're incompatible"
Someone could absolutely print an appropriately shaped phone housing with
new LCD screen drivers for the pro's board, and the correctly shaped ribbon cables.
So, yeeees? it is, but without financial incentive, it's unlikely anyone will make this happen.
Specifically
The wiki does not state that, no.
  PinePhone Pro disable Volume Buttons when malfunctioning ArchBene 1 2,817 07-01-2026, 10:53 AM
Last Post: FR_IV
  Fix Bricked SPI Flash, Pinephone Pro FR_IV 0 662 06-27-2026, 05:00 PM
Last Post: FR_IV
  performance wise which iphone does the pinephone pro compare to? heocb 2 2,344 01-24-2026, 01:01 PM
Last Post: heocb
Exclamation Pinephone pro stuck while booting Supervisor 3 3,768 10-07-2025, 02:46 PM
Last Post: Supervisor
Question Are there plannes to create a new and more powerfull PinePhone Pro? Nima0908 5 14,342 08-18-2025, 04:12 AM
  Pinephone pro packet injection for internal wifi chipset covar 3 6,376 07-02-2025, 02:03 PM
  RTKLIB PinePhone Pro GPS jlaba 1 2,615 05-02-2025, 12:43 AM
  PinePhone Pro Explorer's edition Qualcomm modem recovery shifras 11 14,331 02-28-2025, 07:03 AM
Last Post: tensa1000
  PinePhone Pro EDL boot by shorting contacts ozkenlc 3 6,543 09-18-2024, 04:59 AM
  PinePhone's LED is blinking, but doesn't start zvavybir 0 2,355 09-06-2024, 02:39 AM
Last Post: zvavybir
