PinePhone Keyboard won't work. read_kb_reg(PPKB_SYS_CONFIG) needs what?
As root, I did,
pacman -Syu
pacman -S git php sdcc make gcc
As a normal user I did,
git clone https://megous.com/git/pinephone-keyboard
cd pinephone-keyboard
make all
As root, I continued with
cp -a Downloads/pinephone-keyboard/build/* /usr/local/bin/
vi /etc/systemd/system/ppkb-i2c-inputd.service
and added,
[Unit]
Description=Pinephone Keyboard Service Daemon
[Service]
Type=simple
ExecStart=/usr/local/bin/ppkb-i2c-inputd
[Install]
WantedBy=multi-user.target
I had no need to blacklist kbd51
lsmod | grep kbd
gave nothing. I did see
pinephone_keyboard    16384  0
at the end of lsmod.
I enabled the new systemd service.
systemctl enable ppkb-i2c-inputd.service
Created symlink /etc/systemd/system/multi-user.target.wants/ppkb-i2c-inputd.service → /etc/systemd/system/ppkb-i2c-inputd.service.
The following did/showed nothing.
systemctl start ppkb-i2c-inputd
ps ax | grep ppkb
gave no match.
I rebooted and found the same results both above and below.
The following command (with the PPP out of and in the ppkb) generated a WARNING and an ERROR.
pkb-i2c-inputd
WARNING: I2C_RDWR failed (6)
ERROR: read_kb_reg(PPKB_SYS_CONFIG) failed: No such device or address
Having inserted the PPP into the ppkb, I found that charging works.
The keys do not work.
How may I obtain "such device or address"?
  PinePhone Pro disable Volume Buttons when malfunctioning ArchBene 1 3,253 07-01-2026, 10:53 AM
Last Post: FR_IV
  Fix Bricked SPI Flash, Pinephone Pro FR_IV 0 789 06-27-2026, 05:00 PM
Last Post: FR_IV
  performance wise which iphone does the pinephone pro compare to? heocb 2 2,592 01-24-2026, 01:01 PM
Last Post: heocb
Exclamation Pinephone pro stuck while booting Supervisor 3 4,080 10-07-2025, 02:46 PM
Last Post: Supervisor
Question Are there plannes to create a new and more powerfull PinePhone Pro? Nima0908 5 14,700 08-18-2025, 04:12 AM
  Pinephone pro packet injection for internal wifi chipset covar 3 6,731 07-02-2025, 02:03 PM
  RTKLIB PinePhone Pro GPS jlaba 1 2,812 05-02-2025, 12:43 AM
  PinePhone Pro Explorer's edition Qualcomm modem recovery shifras 11 14,940 02-28-2025, 07:03 AM
Last Post: tensa1000
  PinePhone Pro EDL boot by shorting contacts ozkenlc 3 6,812 09-18-2024, 04:59 AM
  PinePhone's LED is blinking, but doesn't start zvavybir 0 2,505 09-06-2024, 02:39 AM
Last Post: zvavybir
