Unsuspend → Black screen
(06-14-2023, 01:32 AM)dante404 Wrote:
(05-09-2023, 07:50 AM)mdk Wrote: Noticed something else!
When the screen stays black the phone is hot.
It often happen while charging, maybe after hitting 100%.
Have to hard reboot.
Same here! Often in the morning (plugged in over night), it's dead...
Currently I THINK it doesn't happen (that often?) when my phone lays NOT completely on it's backside while charing over night but gets more 'ventilation'/fresh air (and so gets less hot)...
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
Currently I THINK it doesn't happen (that often?) when my phone lays NOT completley on it's backside while charing over night but gets more 'ventilation'/fresh air (and so gets less hot)...
My phone barely even gets warm with the keyboard case acting as both a larger sink and I never lay it phone side down. The device itself just never wakes from sleep.
I think this mornings update MIGHT have fixed it, but need more time to confirm
Edit: nope
(06-16-2023, 07:08 AM)Melechtna Wrote: My phone barely even gets warm with the keyboard case acting as both a larger sink and I never lay it phone side down. The device itself just never wakes from sleep.
Interesting. Mine gets really warm/hot when charging, and is always warm when 'dead' in the morning I think...
You're probably using a charger that pumps out close to the devices limit. I had a similar issue when I initially tried to charge it with a Pixel brick that was at the highest recommended limit of the device. Switching to one with a lower amperage, I think 0.5 amps less, it didn't overheat near as bad, With the keyboard case however, I can plug this charger into the case, and the lower one into the phone, and it makes it charge "faster", without the overheating issue either.
Interesting, I will have to look into this and probably get an other charger... Thanks!
@topic: It seems that the position (or 'cooling') of the phone doesn't really matter, I think now I was wrong on this. (Or... that has changed because of summer... Wink )
To be clear, it IS against the user manual for the keyboard case to do this, the dual charging I mean, but the device crashes if it's too low on battery, so that's why I do this sometimes. My device is one that has the "battery won't charge" issue with the case, but I'm working on it.
  OpenTTD game - Error: no usable screen resolutions found. eugenr 3 6,763 06-23-2026, 01:12 AM
Last Post: Mary_Davis
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,512 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 12,284 12-23-2025, 04:25 AM
  How to add an homemade app to the main screen? JChdeL 3 2,556 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 3,733 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,728 01-15-2025, 08:08 PM
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 10,933 08-05-2024, 06:12 AM
Last Post: baptx
  Screen auto-rotation sensitivity mdk 0 2,566 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 2,685 06-24-2023, 01:55 PM
Last Post: freelectro
  Lock screen question: always squeekboard tuxcall 1 3,762 02-02-2023, 08:51 PM
Last Post: Haibara23
