Another stuck watch!
Sounds as if the watch already is paired in the Android bluetooth settings itself. You could try to see if it's there and if so delete it.
From a home screen, navigate to Settings-->Connections-->Bluetooth
If any "Pinetime" or "Infinitime" devices are connected, tap the appropriate device name or the Settings icon (right)
Tap 'Forget' or 'Unpair'.
Open GadgetBridge and try scanning for the device.
Good luck!
Gary
(06-07-2023, 07:23 AM)GaryM Wrote: Sounds as if the watch already is paired in the Android bluetooth settings itself. You could try to see if it's there and if so delete it.
Good luck!
Gary
THAT WORKED!!!
Ha, amazing. So simple, I never thought to look in Android's bluetooth connections and remove it from there Smile
Many thanks for staying with me and helping out!
  Need help with updating firmware on brand new watch sabersoul1217 0 1,033 07-12-2026, 07:05 PM
Last Post: sabersoul1217
  Custom Watch Faces Performance sophiasmith 0 2,109 01-03-2026, 02:23 AM
Last Post: sophiasmith
  Making watch vibrate using Python from a Raspberry Pi YoungRechnitz 0 2,305 03-27-2025, 03:51 PM
Last Post: YoungRechnitz
  Stuck in OTA update mode mark1250 4 9,002 06-01-2023, 10:06 AM
Last Post: feketej
  Update of new watch consistently fails bitreaper 5 10,187 06-01-2023, 02:29 AM
Last Post: feketej
Exclamation Stuck at Infinitime Logo with 18% battery on full charge? PiningFjord 1 3,809 03-13-2023, 05:05 PM
Last Post: PiningFjord
Question Green skin-facing LED stuck on aereaux 0 2,342 03-05-2023, 02:02 PM
Last Post: aereaux
  Pinetime stuck at infinitime logo monto 3 6,771 08-27-2022, 11:26 AM
Last Post: monto
  Whoops! Developing games on this (apparently not Linux) watch. Www 2 5,368 06-26-2022, 07:12 AM
Last Post: Www
Question Open box, upgrade, dead watch? ahaplesshappenstance 5 8,313 06-25-2022, 03:13 PM
Last Post: ahaplesshappenstance
