Pinephone - broken power button
So, I have been using my Pinephone, in a wallet case not designed for it, on a temporary basis. Was working well, but had to pop the Pinephone out of the case to press the power button.
Suddenly, a very soft "ping". The little dish-shaped aluminium plate came off the power button, revealing the two contacts (the inner copper dot and outer copper ring).
Power button still works if I short across the contacts with a conductive object.
Fixing the little aluminium plate back in place with a touch of cyanoacrylate glue did not restore the power button's function, had to remove it again.
Spoke to a friend we all call "MacGyver", he doesn't like even his chances of repairing a little momentary power button, says he's succeeded twice on about fifty devices attempted.
I need a replacement power button for the Pinephone. I've searched the datasheets and component list hoping for a component ID for the little momentary power button, but it only lists the larger modules.
Does anyone know what a suitable replacement button would be? Digikey component number or a link to eBay / Aliexpress would be most welcome!
(03-16-2021, 02:58 AM)rorus Wrote: ...
I guess what you need is 1 of these.
Sadly (but realistically - I realise P&P costs despite what fleabay would have me believe!) the P&P far outweighs the cost of the item though. If you are in the UK then there are some little bits I have been thinking of and could share the P&P?
Are we talking about this? https://pine64.com/product/pinephone-sid...46c16e2e66
No, this side flexband PCB does not include the small round bottons.
Thanks guys.
I'm in Australia, not the UK, but definitely interested if anyone has a source for a replacement!
(03-30-2021, 12:06 AM)rorus Wrote: Thanks guys.
The actual power and volume buttons are actually a part of the LCD screen. When you order a new screen, they send you a tiny decal with contacts on it to short the membranes on those tiny contacts when you depress the plastic outside part. $35USD
the part you are talking about is the "PINEPHONE SIDE KEYS FLEX PCB" and costs only 1 USD
I did not realize that was in the Pine Store (plus $15 shipping )
I ordered it (30/03) after reading the discussion, will let you guys know how the replacement goes when it arrives. Thanks everyone for your advice!
Were you able to replace this? Having a very similar issue with my power button
(04-05-2021, 04:21 PM)KNERD Wrote: The actual power and volume buttons are actually a part of the LCD screen.  When you order a new screen, they send you a tiny decal with contacts on it to short the membranes on those tiny contacts when you depress the plastic outside part.  $35USD
https://pine64.com/product/pinephone-sid...-flex-pcb/
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 23,700 09-11-2026, 09:18 AM
Last Post: idice
  Pinephone + Keyboard for sale, little use ruemoo 18 15,653 08-23-2026, 12:17 AM
Last Post: Nambo
  PinePhone 16 GB – Free to a Good Home Anna 2 2,582 01-20-2026, 01:43 PM
Last Post: Anna
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 9,028 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 4,549 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 3,607 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 7,137 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 5,309 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 3,900 03-25-2025, 08:51 PM
  various tricks to open the pinephone shengchieh 3 6,331 09-16-2024, 03:42 AM
