My PinePhone Pro does not read the micro SD card at all.
Hi!
I tried booting from SD card as indicated here: https://wiki.pine64.org/wiki/PinePhone_Pro#Boot_from_microSD_card_temporarily.
I also tried holding the RE button.
Nothing works and the operating system does not detect any SD card.
The microSD card is inserted all the way...
[Image: gXPySj4G]
[Image: 7GmC3ZWs]
(03-23-2023, 03:34 PM)tux_life Wrote: Hi!
[Image: gXPySj4G]
[Image: 7GmC3ZWs]
RE button is not necessary in that case, holding "volume down" at boot is sufficient as it seems that you bought your phone after July 2022. Though the OS not detecting the card is not a good sign, booting from it will not work in that case either.
The card looks inserted correctly and it's a very basic functionality which is expected to work, unless something is broken (card, card reader).
Did you try a different card? This one looks like it already went through a lot of things.
(03-23-2023, 06:24 PM)fxc Wrote: Did you try a different card? This one looks like it already went through a lot of things.
I tried with three different ones.
Looks like a defective board then. You might want to check if the microSD card detection pin broke off by looking from the side. Would suggest to open a ticket under https://support.pine64.org.
Thank you!!!
I solved the problem by lifting the pins.
The card reader works now and I can boot from SD.
Thanks and sorry for my bad english.
Thank you!!!
On a side note, mind that you can also flash the eMMC using Tow-Boot's USB Mass Storage mode (hold volume up at boot).
Thank you!!!
I have this same problem.  I figured it's a problem with the reader (i.e. the hardware), but haven't fixed it, yet.  Support was no help.
@tux_life  You "lifted the pins"?  How?  What did you do?  This seems as if it maybe a solution for me, too.
(03-25-2023, 11:43 AM)_radv_ Wrote: I have this same problem.  I figured it's a problem with the reader (i.e. the hardware), but haven't fixed it, yet.  Support was no help.
In my case it may be that I myself somehow damaged the reader.
Anyway...as suggested by fxc I looked at the pins and noticed some were down. I raised them up a bit with a small screwdriver. My English is very bad, so I hope I was clear.
  PinePhone Pro disable Volume Buttons when malfunctioning ArchBene 1 2,525 07-01-2026, 10:53 AM
Last Post: FR_IV
  Fix Bricked SPI Flash, Pinephone Pro FR_IV 0 550 06-27-2026, 05:00 PM
Last Post: FR_IV
  performance wise which iphone does the pinephone pro compare to? heocb 2 2,176 01-24-2026, 01:01 PM
Last Post: heocb
Exclamation Pinephone pro stuck while booting Supervisor 3 3,555 10-07-2025, 02:46 PM
Last Post: Supervisor
Question Are there plannes to create a new and more powerfull PinePhone Pro? Nima0908 5 14,003 08-18-2025, 04:12 AM
  Pinephone pro packet injection for internal wifi chipset covar 3 6,119 07-02-2025, 02:03 PM
  RTKLIB PinePhone Pro GPS jlaba 1 2,466 05-02-2025, 12:43 AM
  PinePhone Pro Explorer's edition Qualcomm modem recovery shifras 11 13,852 02-28-2025, 07:03 AM
Last Post: tensa1000
  BOOT ERROR: Failure to read device ID drh 1 2,651 02-15-2025, 07:20 PM
Last Post: drh
  PinePhone Pro EDL boot by shorting contacts ozkenlc 3 6,307 09-18-2024, 04:59 AM
