Battery Issue or Power Management IC?
Thumbs Down
Hi all.
For over two years, I've had a great time using my PinePhone as a daily driver under postmarketOS edge. Up to this point, I've been able to overcome just about any issue. However, I've suddenly run into a hardware problem, which I can't seem to troubleshoot...
Here are the symptoms:
  1. The phone will start to boot, (green LED lights), but about 1 second into the ToW boot loader the LED just goes dark.
  2. Plugging in a USB-C cable from my labtop results in a boot loop; the phone will boot until the OS splash screen flickers for a brief moment before repeating.
  3. Plugging in a slow USB-1.2 charger allows the phone to boot normally. However, I noticed that my battery status indicated a 100% charge state. (I have always set the OS to undercharge to no more than 90%...)
  4. The phone also boots normally on a slow USB-1.2 charger with the battery removed. The battery status indicated a 0% charge state, in this case.
  5. In either case #3 or #4, all radios are disabled within the OS.
Given the above, I just assumed that I somehow had drained battery too far...
Except the following seems to conflict with this:
  1. I booted from a SDcard Jumpdrive using a USB-1.2 power source. It boots fine to the Jumpdrive splash.
  2. I then let it sit for hours attempting to slowly bring the phone battery back to life.
  3. This Jumpdrive charge method did not seem to work. Pulling the charging cable immediately kills the phone, and attempting to boot from the battery has the same symptoms as above.
  4. Measuring the voltage across the battery terminals shows 4.2V, though... This indicates a fully charged lithium-ion battery under no-load, correct?
So, at this point, I am at a total loss...
It would appear that I've a fully charged battery. However, the symptoms are the same as a drained battery.
I could really appreciate any suggestions that could help.
(03-18-2023, 06:22 PM)bcoyle Wrote: Hi all.
The symptoms do indeed describe a drained battery. Your point one from the second list is not a contradiction to that, Jumpdrive is one of the few things actually booting with a drained battery. The battery measuring 4.2V is strange. Maybe it would be a good idea to buy a compatible battery from Amazon and check if it works with it, otherwise you could always send the battery back.
OK. Hopefully, others will benefit from this thread. I've got a troubleshooting follow-up:
I was able to borrow my friend's Pinephone. As expected from the 4.2V battery measure, my "suspect" battery works fine in his device. I also swapped his working battery into my phone. The no-boot symptom on battery power still remains...
To summarize:
  1. No boot occurs off the battery. The green LED briefly lights for a second before going dark.
  2. Booting occurs normally when powered from a v1.2 USB port, but all wireless radios appear as disabled.
  3. A boot loop occurs when powered from a USB-C port or power adapter.
  4. The battery reads fully charged with a DVM and tests out normally in another device.
Clearly this behavior is with the phone hardware, not a drained battery. Has anyone experience anything like this before, or does anyone have a theory to a root-cause? Any suggested fixes or next steps?
  Battery life improvement freelectro 11 13,319 09-14-2026, 08:53 AM
Last Post: Juergen
  Pinephone - broken power button rorus 14 26,623 05-17-2026, 03:52 PM
Last Post: EuvzO8
  Battery connector dead mdk 5 5,500 01-15-2026, 02:24 PM
Last Post: mikeb
  Battery Life- hardware abstraction layer-GPU VS optomizing app for GPU-openGL biketool 1 4,023 09-20-2024, 04:04 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 5,457 02-17-2024, 04:15 PM
Last Post: vortex
Bug DESIGN ISSUE? Speaker + vibration motor broke for the 2nd time e1337 11 13,654 01-26-2023, 10:11 PM
Last Post: AnAbolitionist
  Power supply vs battery albafrati 11 14,022 06-22-2022, 06:04 PM
Last Post: albafrati
  Odd Issue CzarD0mn 3 5,711 06-12-2022, 02:36 PM
Last Post: alaraajavamma
  What PD charger/dock combo results in PP battery not draining while using convergence james8880 0 3,904 04-28-2022, 12:45 PM
Last Post: james8880
  Battery mot charging past 54% StickyPine 32 53,817 02-26-2022, 02:07 AM
Last Post: vusra
