VPN for PostmarketOS
Are there any VPN's that work on PostmarketOS ? I would be using on the Pinephone CE; Pinebook Pro and Rock Pro 64. I usually use Proton VPN or Mullvad but i'm not overly picky.
PinePhone BraveHeart Edition
Pinephone Convergence
PineTab
RockPro64
You do not necessarily need to use the VPN provider's official client. (I do not expect the official clients to work well on mobile GNU/Linux. Especially not on PostmarketOS which, being based on Alpine, uses musl instead of glibc.) Both Proton VPN and Mullvad support multiple standard protocols that have Free Software  / Open Source clients available (OpenVPN and at least one other standard protocol). Those can be used with the NetworkManager plugins that should be available from the PostmarketOS (or Alpine) repositories.
How well NetworkManager VPN plugins work depends on the GUI environment you are using. The one I am familiar with, Plasma Mobile, does not really support VPNs, but they can be set up using the desktop dialog "kcmshell5 networkmanagement". Then, if I type "nmcli c up thenameofthevpn" in a terminal (using the virtual keyboard) or run a script for it, that brings up the plasma-networkmanagement (desktop) dialog for the username and password (which can be saved, then you only have to click a button twice the next time you need to log in). The dialog is somewhat truncated, but enough of it is visible to log in successfully. To disconnect, use "nmcli c down thenameofthevpn".
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 3 7,528 11-18-2024, 02:23 AM
Last Post: linmob
  How to include desktop file and icon in a postmarketos package patrickMcDonald 0 3,236 07-27-2023, 12:34 PM
Last Post: patrickMcDonald
  installed postmarketos v23.06 no audio samlo 1 4,367 07-14-2023, 12:53 AM
Last Post: samlo
  Scanning with PostmarketOS AndyM 1 3,893 07-01-2023, 08:16 AM
Last Post: AndyM
  Pinephone 64 PostMarketOS edition Battery Issues, Not Hardware Issue X0X0X0X0X0 1 4,847 02-11-2023, 08:19 AM
Last Post: acid andy
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 4,190 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
  no screen rotation on pinephone pro with postmarketOS + phosh elode 2 6,270 07-03-2022, 09:13 AM
Last Post: a.h.littorin
  Pinephone Keyboard Utilities on postmarketOS elof 2 7,075 06-20-2022, 01:33 PM
Last Post: elof
  Best Place To Learn PostmarketOS mw4jet 6 12,608 01-30-2022, 11:57 PM
Last Post: arcanemachine
  [PostmarketOS with Plasma Mobile] Angelfish adblock + wpa supplicant time out Egolep 0 3,504 03-23-2021, 10:25 AM
Last Post: Egolep
