Pinephone lost graphic during mobian system upgrade
Wink
I just bought an pinephone and I am still learning. I recently flash mobia with full disk encryption. While updating the system using "apt full-upgrade" the system screen turn black. After line the whole day I restart the phone and I endup with no graphic. mobian login from console.
(10-18-2022, 12:55 AM)cmpin Wrote: I just bought an pinephone and I am still learning. I recently flash mobia with full disk encryption. While updating the system using "apt full-upgrade" the system screen turn black. After line the whole day I restart the phone and I endup with no graphic. mobian login from console.
Do you get the decypt password question before black screen?
Is it the same problem than mine?
https://forum.pine64.org/showthread.php?tid=17899
(02-28-2023, 12:40 PM)anonymous Wrote: Is it the same problem than mine?
Mine new install does the same as yours. I had to reinstall last year due to upgrade stopping the system even booting. Just got red led flash and haptic for 5sec and then it turned off.
Have you tried to reinstall, disable greetd and re-enable phosh before upgrading like I did?
  Mobian MMS/SMS text problem bcnaz 16 39,996 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,926 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 70,625 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 74,570 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,495 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 351,555 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,167 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,388 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,145 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,827 04-29-2025, 02:10 PM
Last Post: mdk
