PinePhone Pro battery life at the beginning of 2023?
Hi there,
just a short question to the PinePhone Pro owners:
How is the battery life today?
I've often read it is very bad (worse than normal PinePhone) BUT this statements were all from 2021, and I guess things have changed a bit (like they did for the normal PinePhone earlier) - So how it is today?
Is the battery life at least as 'good' as on the normal/classic PinePhone (non-Pro)?
My normal PinePhone today just manages to get me through a work day (which is not great but OK... but shorter battery life would be a problem), would be the Pro be comparable today?
(And please add your operation system in the answer, perhaps it makes a difference.)
Thanks for any reply!!  Smile
Best Regards,
dante404
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
(02-13-2023, 02:28 AM)dante404 Wrote: Hi there,
Best Regards,
dante404
4 to 6 hrs for me.  The Older PP batteries work fine in the Pro.
(02-13-2023, 09:24 AM)iwm Wrote: 4 to 6 hrs for me.  The Older PP batteries work fine in the Pro.
Thank you for your reply! Smile
Sorry, another question: "4 to 6 hrs" active or with (longer) deep sleep phases or...?
My classic PinePhone gets me through a 12 hours day without charging, but really used (browsing and messaging) is it only for about 2 hours maximum (summarized) I guess, the rest of the time it sleeps. Do you think the Pro would do similar today? Smile
My Pro runs down pretty fast.  Does hold most of charge if not turned on for the day.  I have not tested the percentage of leakage. I would venture to say maybe 5% / hour.
(02-14-2023, 10:10 AM)iwm Wrote: My Pro runs down pretty fast.  Does hold most of charge if not turned on for the day.  I have not tested the percentage of leakage. I would venture to say maybe 5% / hour.
Thank you for sharing your experiences!
That would mean... it would last somewhat about 20 hours if on but in sleep mode all the time.
What would you think/guess it loses (percentage) if actively used for about an hour (just display, wifi, browsing, no video streaming or stuff like that) ? Just a spontaneous wild guess please (I know you can't tell exactly of course)...? Smile
It's really sad (especially for a product like PinePhone Pro) that all the tech websites and youtubers out there only review stuff when it's "new and hot!!!"... and never come back to check how things have changed for example 1 year after product release (about battery life and other areas). Sad
(Perhaps a "revisit" doesn't generate as much klicks for them, I don't know.)
No PinePhone Pro-user wanting to share his expierence? Sad
Would be important if it could at least "make it through a day" with not excessive usage (like OG PP).
I guess there must be also some people here who have used both PinePhone variants in the last months and know if there is still any noticable difference in battery life (or not)... Sad
(02-22-2023, 03:08 AM)dante404 Wrote: No PinePhone Pro-user wanting to share his expierence? Sad
Hi!
I have been tinkering with PPP now like one week.
I am still trying to find out what the fck is going on with PPP audio because it is really really mess Big Grin - so I can't really daily drive it perfectly.
If someone knows image where audio works nearly flawless without need to use wired headphones or similar I would like hear Smile
(I have tried pmos, mobian, manjaro and arch)
BUT I think I have good news for you and other who are considering PPP.
In my use case and IMO (not a fact but this is how I see it) PPP battery life is as good or even better if I compare it to over a year old PP.
If I use PPP it will drain faster yes but if I compare what I can do with it for example in 5 minutes the difference to PP and PPP is like night and day.
So for example reading daily headlines trough Firefox will take 5 minutes with PPP and 15 minutes with PP
Hope this helps. I will write more and even more when I found out how I can achieve working audio with PPP Big Grin
(02-22-2023, 11:31 AM)alaraajavamma Wrote: BUT I think I have good news for you and other who are considering PPP.
Thank you very much, that's great to hear and very interesting! Smile
(Sad though that audio is still such a mess on PPP it seems Sad , I will search for additional information about this.)
my main problem with PP is that modem drains battery very quickly when in a call. So it would be interesting how PPP permors in a call. How many hours can it be used for talking over GSM?
  "USB access to SD" disappeared on a Pinephone Pro jebez 0 534 06-19-2026, 06:40 PM
Last Post: jebez
  Can't detect the phone's battery shanewilliam 2 1,254 05-17-2026, 04:49 AM
Last Post: drh
  what stopped pinephone pro? heocb 1 1,510 01-14-2026, 09:56 AM
  PinePhone Pro: Camera App very laggy Martin87 3 5,636 08-22-2025, 11:23 PM
Last Post: teekay
  PinePhone Pro discontinued teekay 9 14,499 08-22-2025, 11:19 PM
Last Post: teekay
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 3,623 08-18-2025, 06:15 PM
  Pinephone pro ee bricked? dennylee 3 2,799 07-22-2025, 12:06 AM
Last Post: Dendrocalamus64
  Full desktop Surfing and Absolute Privacy on the pinephone? Www 8 4,751 06-30-2025, 10:51 AM
  Backing up data on Pinephone Pro to hard disk, optical disk and flash? Www 4 3,315 06-29-2025, 02:46 PM
  Printing and scanning documents with pinephone? Www 4 3,350 06-29-2025, 11:48 AM
