PBP solid orange light and does not start
I have a 14" PBP that I had been using normally in North America. Since I moved to Europe I have not been able to boot it. When I connect the barrel charger the light stays orange/red. Sometimes I get the manjaro logo for a few seconds and then the screen goes black. I am wondering if there could be a voltage issue or if I should try to switch off the eMMC (as suggested here: https://forum.pine64.org/showthread.php?tid=10093).
Thanks!
Well, the important part is not disabling the eMMC. The important part is replacing U-Boot. If you don't have a USB to eMMC adaptor, you will have to disable the eMMC and re-enable it during boot.
I have a USB to eMMC adaptor and I've never used it. Since I haveto open the PNP
PBP anyway, I just do the eMMC disable/re-enable thing.
Also, it sounds as if your battery is dead or very low. Try to charge the PBP overnight, powered off, with a USB-C cable (unplug the barrel charger for this!)
:wq
  red charge light goes out gilwood 19 16,872 02-10-2024, 10:28 AM
Last Post: gilwood
  No start button light gilwood 6 7,072 02-09-2024, 08:31 AM
Last Post: gilwood
  Troubleshooting of pinebook Pro red light and black screen wangyukunshan 0 4,056 03-23-2022, 12:10 AM
Last Post: wangyukunshan
  Blinking red light for charger, no power-on bifo 11 32,437 11-30-2021, 01:37 PM
Sad PBP won't start woschtsuppe23 2 6,013 06-07-2020, 10:56 AM
Last Post: xmixahlx
