My screen bottom side has loosed its tactile function
My screen bottom side has loosed its tactile function (I don't know if it's a hardware screen issue or just a bad connection of the screen). But, meanwhile, I have a problem to start my mobile because the OK button, when decrypting the device at the starting process (my device is encrypted) is very hard to touch (I should try dozens of times). I wonder if I can set:
an inversion of top/bottom sides, at mobile start, or always (when I'm in the graphical screes, auto rotate help me, there is not a major issue)
"Cancel" the bottom last centimeter of the screen.
Are there any settings file where I can modify these parameters?
if you can't find a solution and you just want to replace the screen, I think they're available in the store and there should be a tutorial somewhere: https://pine64.com/product/pinephone-5-9...ch-screen/
  PinePhone Boots but only Shows Black Screen with Backlight danyeaw 1 3,249 06-30-2024, 10:18 AM
Last Post: danyeaw
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 14,218 08-28-2023, 11:38 AM
Last Post: fxc
  locked out on PIN screen g40 1 3,069 06-07-2023, 10:20 PM
Sad New PinePhone won't boot 9/10 times - Screen is on but stays black :( dante404 8 12,954 02-03-2023, 01:27 AM
Last Post: dante404
  "PinenotePhone": Swap E-Ink Screen Onto Pinephone? britelite 0 2,306 01-03-2023, 06:17 PM
Last Post: britelite
  Screen seems ok but no display UncleMeat 3 6,277 11-03-2022, 07:02 AM
Last Post: fxc
Question Black screen no matter the OS joseph303 2 4,537 07-19-2022, 01:07 AM
Last Post: joseph303
  Boot problem: wrong screen orientation Jetpac 6 9,196 07-18-2022, 12:47 PM
Last Post: fravoi
  Manjaro phosh no screen rotation sandspur 1 3,975 06-23-2022, 01:02 AM
Last Post: rapp
  Mute function on calls? scrwbigtek 0 2,202 05-30-2022, 12:52 PM
Last Post: scrwbigtek
