No modems were found: No mobile data, no 2G
Exclamation
Hello
I'm unable to bring up the modem, restarting eg25-manager has no effect, I have no longer any prompt to enter my PIN code. This problem appeared last week on my very first Pinephone which is two years old, the operating system is up-to-date (bookworm). I'm completely stuck as my second Pinephone doesn't work too Sad
I tried:
sudo systemctl restart eg25-manager
mmcli -S
Do you have a suggestion?
(12-26-2022, 12:27 PM)anonymous Wrote: Hello
I tried:
mmcli -S
i'm testing mobian as of now and i didn't notice anything weird (in regards of modem). although, i don't use sim pin codes.
let's start with these, what following commands tell.
## $ mmcli -L ## $ lsusb
I tried:
mmcli -S
mmcli -L printed "No modems were found". As the touchscreen is broken, I preferred using my second Pinephone, I replaced Manjaro KDE by Mobian, I installed Tow-Boot and I used mobian-installer-pinephone-phosh-20221120.img (very important as the very latest installer doesn't work). Everything works like a charm now. I'll try lsusb by curiosity one day if my first broken Pinephone works a bit soon.
  OpenTTD game - Error: no usable screen resolutions found. eugenr 3 6,658 06-23-2026, 01:12 AM
Last Post: Mary_Davis
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 8,353 02-20-2025, 02:47 PM
Last Post: puffchumpy
  Mobile internet via cellular network mostly not working Anna 18 27,399 01-19-2024, 02:59 AM
Last Post: anonymous
  4G data on default startup / boot dcinoz 1 3,222 04-29-2023, 11:24 PM
Last Post: dcinoz
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 3,016 03-06-2023, 12:06 PM
Last Post: freelectro
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 5,551 01-07-2023, 09:36 AM
Last Post: dcarvil
  very slow processing of MMS received via Ting (T-Mobile) treebeard 6 9,192 12-01-2022, 09:18 AM
Last Post: traut
  DNS Problems with Mobile Data arno_nuehm 29 41,245 10-29-2022, 09:16 AM
Last Post: treebeard
  Amberol Mobile Music player(flatpak) biketool 0 2,533 06-19-2022, 07:16 AM
  Cellular data is working! drh 0 2,299 05-15-2022, 09:02 AM
Last Post: drh
