SIM Card Slot Terror
Today, I joined the ranks of those unfortunate souls who have ruined their Micro sim card slot by breaking one of its pins while using the Nano adapter.
What I'm wondering now is what is my best option is to set things right.
Should I buy one of the new motherboards with a Nano sim card slot?  Or is the sim card slot itself replaceable by people without superhuman soldering skills? Or is there another solution that someone has had luck with?
Thanks in advance, al!
I hope I’m wrong, but I think only the PinePhone Pro motherboards got the nano sim card slot.
It's the sort of solder job a phone repair place should probably be able to do, so long as you can get the part. @tllim said a while back that they had obtained some spares which you might be able to get by filing a support ticket. It's also been suggested the LG G4 has a socket that's a close match, but I don't know if anyone has actually tried it as a replacement. It wouldn't hurt to ask how much it would cost for the soldering, then judge whether it's worth a try or better just to replace it.
Just file a support ticket at https://support.pine64.org, support team will arrange a free microSD/microSD socket but user needs to pay for the shipping cost.
Awesome, @tllim! I just created the support ticket. Thanks for the advice!
  install iso from sd card to emmc aular 2 4,070 03-11-2024, 10:24 PM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 4,781 01-09-2024, 07:02 PM
Last Post: britelite
  new pinephone regular model with nano-sim slot zetabeta 0 2,038 09-24-2023, 12:25 AM
Last Post: zetabeta
  SD Card has wrong capacity AndyM 11 10,871 06-11-2023, 12:30 AM
Last Post: AndyM
  Device Unable To Read MicroSD Card _radv_ 19 20,094 02-18-2023, 02:01 PM
Last Post: _radv_
  MicroSD Card Reuse _radv_ 5 7,003 12-12-2022, 12:26 PM
Last Post: chainingsolid
  Pine Phone Doesn't Recognize New MicroSD Card _radv_ 3 4,795 11-23-2022, 05:19 AM
Last Post: _radv_
  SIM Card Install pineme 4 9,346 06-10-2022, 03:15 AM
Last Post: rocket2nfinity
  SIM card slot not working dekrets 2 5,108 02-12-2022, 11:09 AM
Last Post: dekrets
  PinePhone SIM slot Niek 14 25,032 01-29-2022, 03:23 PM
Last Post: u20200719
