Receive MMS fails after Nov 27 upgrade
(12-06-2022, 01:46 PM)treebeard Wrote:
(12-06-2022, 06:38 AM)anonymous Wrote: Does it have anything to do with the support of multiple APNs?
By the way, the logs mention something about a missing symbol in my case, it doesn't work.
No, I think multiple APN support is still a ways away.  It involves changes to multiple packages, and I don't think anyone is actively working on the problem.
My only guess is that you've got an incompatible mix of packages.  Have you done a dist-upgrade, or are you instead installing individual packages?  What is the missing symbol message?
I don't find the message about a missing symbol but I see this message:
déc. 06 19:22:16 mobian mmsdtng[8374]: ../plugins/modemmanager.c:set_context() Setting Context...
déc. 06 19:22:16 mobian mmsdtng[8374]: ../src/service.c:mms_service_set_mmsc() service 0x55acf5d7f0 mmsc http://mms.orange.fr
déc. 06 19:22:16 mobian mmsdtng[8374]: ../plugins/modemmanager.c:set_context() Max number of bearers: 1
déc. 06 19:22:16 mobian mmsdtng[8374]: ../plugins/modemmanager.c:set_context() Current Context APN: orange, mmsd-tng settings MMS APN: orange.acte
déc. 06 19:22:16 mobian mmsdtng[8374]: ../plugins/modemmanager.c:set_context() The modem is not connected to the correct APN!
déc. 06 19:22:16 mobian mmsdtng[8374]: ../plugins/modemmanager.c:bearer_handler() Set MMSC: http://mms.orange.fr, Set Proxy: 192.168.10.200:8080, Set MMS APN: orange.acte
déc. 06 19:22:16 mobian mmsdtng[8374]: ../plugins/modemmanager.c:bearer_handler() At Bearer Handler: path /org/freedesktop/ModemManager1/Modem/36 active 1 context_active 0
déc. 06 19:22:16 mobian mmsdtng[8374]: ../plugins/modemmanager.c:bearer_handler() Error activating context!
déc. 06 19:22:16 mobian mmsdtng[8374]: ../src/service.c:mms_service_bearer_notify() service=0x55acf5d7f0 active=0 iface=(null) proxy=(null)
déc. 06 19:22:16 mobian chatty[20035]: Bearer Handler emitted an error, the APN set in mmsd's settings does not match any connected APNs
(12-06-2022, 03:47 PM)anonymous Wrote: I don't find the message about a missing symbol but I see this message:
The APN configured for MMS messages in chatty must be identical to the APN selected in gnome-control-center in order to receive MMS messages.  Once they match you'll see "You are connected to the correct APN! Enabling context..." instead of "The modem is not connected to the correct APN!"p, li { white-space: pre-wrap; }
When I choose orange.acte in Gnome Control Center, I still get "Error activating context!". I'll post a longer part of the logs.
(12-07-2022, 05:56 AM)anonymous Wrote: When I choose orange.acte in Gnome Control Center, I still get "Error activating context!". I'll post a longer part of the logs.
Maybe you should start a new thread?  Sounds like your issue might not actually be related to this topic.
Actually, it's related and according mmsd-tng maintainer, it's specific to the version 2.0 beta. Do you know when the version 2.0 will be released?
I see your conversation in the gitlab.  Looks like 2.0 should hit bookworm in a couple days.  You can watch the progress here.
(12-11-2022, 08:21 AM)treebeard Wrote: I see your conversation in the gitlab.  Looks like 2.0 should hit bookworm in a couple days.  You can watch the progress here.
...or if you don't want to wait, you can probably get away with downloading mmsd-tng_2.0.0-1_arm64.deb now and doing a "dpkg -i mmsd-tng_2.0.0-1_arm64.deb".  I don't see any dependency changes (versus the beta).
MMS receiving works anew since the last update to mmsd-tng 2.0.0 as announced, I got it a few hours ago Smile
  Full disk encryption with calamares: beware of last testing upgrade! mdk 3 5,687 02-21-2025, 07:25 AM
Last Post: dragonhospital
  Upgrade to Mobian (Trixie) Staging biketool 13 11,391 12-29-2024, 10:35 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 2,456 09-01-2023, 11:29 AM
Last Post: Mahgue
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 6,905 03-01-2023, 04:45 PM
Last Post: anonymous
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 3,525 01-04-2023, 06:46 PM
Last Post: 3x5co
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 11,711 09-30-2022, 08:53 PM
Last Post: treebeard
  Modem Firmware Upgrade - Modem Busy - USB Issues biketool 10 14,453 09-23-2022, 05:15 AM
  New Tow-boot release, how to upgrade? user641 3 5,432 08-23-2022, 08:45 AM
Last Post: user641
  GPS/location services don't work with Maps after Bookworm upgrade Anna 16 23,437 06-13-2022, 02:37 PM
Last Post: wibble
  Firmware upgrade via fwupd user641 3 5,992 04-24-2022, 11:01 AM
Last Post: yehudac
