PinePhone carrier support in Hungary
I could not get the PinePhone working with Yettel LTE network in Hungary.
The wiki says it is supported. (The entry was added by @dachalife.)
The modem connects to the cell towers (LTE), with good signal strength, and recognizes that it is on Yettel HU network. It also displays some information about the network.
The APN credentials in the Pine64 wiki are correct.
APN name: Yettel
APN address: online
The same information can be found at yettel.hu website. I also asked it personally, and online from the customer support, they said the same. The online customer support also said that the APN setting have to be IPv4 only. It wasn't mentioned by the other sources, so I don't know if it's up to date.
I tried the above settings, both with IPv4v6 and IPv4 bearer settings.
It always fails to connect, and it says “Error: unknown APN name”.
SMS sending works. I couldn't test calls as I have a data-only subscription.
Edit for link & clarity:
Yettel used to be called Telenor and never changed the name.
https://wiki.pine64.org/wiki/PinePhone_A..._(Hungary)
PinePhone, Pinebook Pro & PineTab2 owner.
(11-21-2022, 06:53 AM)dachalife Wrote: The APN for Yettel is Telenor
Could you post the exact APN settings that works for you?
Do you still use Yettel on your PinePhone?
I have a data-only plan. Could it be the issue?
Sajnálom, a régi Telenor beállításokat kell használnia; elírtam
I have tried it with this setting also:
APN: online
This doesn't work either.
I used Phosh network settings application on postmarketOS.
I will try it with another distro.
After asking countless times from several employees, I finally got a different answer from one. Turns out, data-only subscriptions require a different APN address.
APN: net
Telenor & online is still functional for NE Hungary (Image attached).
Edit: I can't connect through the yettel one, just tried.
(12-14-2022, 11:52 AM)dachalife Wrote: Telenor & online is still functional for NE Hungary (Image attached).
According to multiple Yettel employees, the name doesn't really matter (so it can be Telenor, or Yettel, or probably anything). The important part is the address of the access point.
You probably have a voice based plan, which means that both calls and mobile data are included in your subscription. Then you have to use the “online” access point.
I have a data-only plan, which doesn't include calls, only mobile data. This is most commonly used in wireless routers, and provides the same data bandwidth for a cheaper price (because calls are excluded). I use a SIM card with this subscription in my PinePhone, because I use a separate phone as the main driver for calls (unfortunately, currently the PinePhone is unreliable for voice calls). I have to use the “net” access point for this subscription.
Yettel Hungary uses separate access points for these two plans, and setting the other on either won't work.
The data-only APN setting is not mentioned on their website, probably to avoid confusion, as this is a rarely used subscription. I got the info from their customer service employees.
  Pinephone + Keyboard for sale, little use ruemoo 16 11,488 07-07-2026, 04:47 PM
Last Post: PinePhoneProUser
  Pinephone - broken power button rorus 14 23,778 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 1,538 01-20-2026, 01:43 PM
Last Post: Anna
Bug PinePhone modem keeps "disappearing" Kevin Kofler 17 19,857 12-12-2025, 03:27 AM
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 7,801 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 3,006 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 2,279 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 5,728 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 4,075 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 2,992 03-25-2025, 08:51 PM
