Axolotl on PinePhone / Mobian
(11-08-2022, 09:18 AM)dante404 Wrote:
(11-01-2022, 04:02 PM)arno_nuehm Wrote: sadly, I cannot recommend to use Axolotl at the moment. There are too many bugs and regressions to be fixed... The team is working their best, but it'll take some more time to make the app usable again.
Strange, I missed one message (image) the last days (AFAIK), but otherwise it seems to work still OK here (use axolotl every day, chatting with multiple different persons). Huh
BTW thanks for your work on Axolotl! Smile
Good for you! Don't change a thing then Smile
And: you're welcome - daily user here, too.
(with an unpublished hot fix version at the moment and still some bugs though...)
...........great, which version are you using........the latest 1.6.0-1? Did not get this to be installed..................
(11-09-2022, 04:02 PM)benedikt55 Wrote: ...........great, which version are you using........the latest 1.6.0-1? Did not get this to be installed..................
1.6.0-1 (deb)
I didn't do anything special when installing it.
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
1.6.0-1 (deb)
Please wait for v1.6.1/v1.7.0, because registration for new users is broken in v1.6.0 and other things for registered users, too.
Sad
Hi all! Since a few days texts are no longer visible in my Axolotl (affects messages and settings, every text, everywhere), everything else is visible (the green and blue bubbles, emojis, images) but no text. I can copy the text (ctrl+a, ctrl+c) and paste it into a editor to read it, so it "is there" but I can't see it! Sad
(I also can't see what I'm typing myself, I only see that the cursor goes right with each char I enter...)
Restarting Axolotl or mobian/PinePhone doesn't help, switching dark mode on or off also doesn't help - And I haven't changed anything in Axolotl for months (using the latest version since october 2022), only did the regular mobian updates (apt upgrade, but no dist-upgrade).
Any Ideas anyone? Am I the only one with this strange problem? Huh
(01-23-2023, 03:46 AM)dante404 Wrote: Hi all! Since a few days texts are no longer visible in my Axolotl (affects messages and settings, every text, everywhere), everything else is visible (the green and blue bubbles, emojis, images) but no text. I can copy the text (ctrl+a, ctrl+c) and paste it into a editor to read it, so it "is there" but I can't see it! Sad
I have exactly the same issue. I have tried deleting the .config/textsecure.nanuc/electron-folder as well as a dpkg-reconfigure, both had no effect whatsoever. Also, sometime in january I stopped getting messages. Signal-desktop on my laptop still works fine, and I'm not referring to the issue where the messages from signal-desktop would not show up on axolotl and vice-versa, just that I'm not receiving messages anymore. This is with 1.6.0.
(01-23-2023, 02:58 PM)battlegarden Wrote: I have exactly the same issue. I have tried deleting the .config/textsecure.nanuc/electron-folder as well as a dpkg-reconfigure, both had no effect whatsoever. Also, sometime in january I stopped getting messages. Signal-desktop on my laptop still works fine, and I'm not referring to the issue where the messages from signal-desktop would not show up on axolotl and vice-versa, just that I'm not receiving messages anymore. This is with 1.6.0.
Interesting! I'm still getting messages (even this morning), I just can't see their text - I'm using axolotl 1.6.0-1 (deb).
@battlegarden : So it seems like we're the only ones affected by this issue Sad (OR some former users don't care for Axolotl and/or the forum any longer, which would be sad of course).
(01-27-2023, 02:54 AM)dante404 Wrote: @battlegarden : So it seems like we're the only ones affected by this issue Sad (OR some former users don't care for Axolotl and/or the forum any longer, which would be sad of course).
I have gone to signal-desktop instead some time ago - couldn't get axolotl working properly in early December. Did require moving my Signal account to an old droid and display on PPP is only viable in landscape but so be it.
(01-27-2023, 04:38 AM)dukla2000 Wrote: I have gone to signal-desktop instead some time ago - couldn't get axolotl working properly in early December. Did require moving my Signal account to an old droid and display on PPP is only viable in landscape but so be it.
So you use signal-desktop (Linux) on your PinePhone? Or just on your PC?
(I'm just curious, I don't have an Android (or Apple) device to set this up anyway.)
  Mobian MMS/SMS text problem bcnaz 16 39,280 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,772 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 68,779 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 73,604 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,401 06-29-2025, 12:38 PM
Last Post: Hiraghm
  VoIP account on mobian dialer j_s 0 3,072 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,251 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,002 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,700 04-29-2025, 02:10 PM
Last Post: mdk
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 7,928 02-20-2025, 02:47 PM
Last Post: puffchumpy
