Axolotl on PinePhone / Mobian
I just noticed that I can no longer send OR recieve pictures via Axolotl (using the latest available .deb-Version "axolotl_1.5.0-1_arm64.deb"). Two days ago recieving still worked (sending is broken for longer) - Do others have the same problem? Did Signal again change something? Sad
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
Just in time:
v1.6.0 is out with plenty of fixes - also for your bug, dante404 (Signal renewed their root ca-cert in the last days).
Download&Installation via
wget https://github.com/nanu-c/axolotl/releases/download/v1.6.0/axolotl_1.6.0-1_arm64.deb && sudo apt install ./axolotl_1.6.0-1_arm64.deb
Backup of the textsecure.nanuc folders in .local/share and .config is recommended since a lot changed in the background.
nanu-c and Blackoverflow did a great job here!
Cheers!
P.S.: First start of v1.6.0 might take a while in order to download the electron binary - as usual ~80Mb.
EDIT: Old chats are not lost. Wait for the counterpart to send a message, then the chat history is back.
(10-27-2022, 03:31 PM)arno_nuehm Wrote: Just in time:
Awesome! Big Grin
Thank you for letting us know!!!
Everything is working again as before (sending and recieving images), some missing old messages (text and pics) were also recieved now. Smile
Didn't work for me. It just flatly kept telling me it can't connect to Signal's servers, perhaps I should unregister and register again.
The captcha is frustrating, the images are so small that it took me quite a while to get through, but eventually I did. Then it told me to enter the six digit code. Well, last time, in early september, I got the SMS from signal. This time not.
Next time I launched it just asked me for a username, so I guess it let me pass without. But then when I tried to add someone to the contacts list, nothing happened.
(10-29-2022, 09:16 AM)Eugo Wrote: Didn't work for me. It just flatly kept telling me it can't connect to Signal's servers, perhaps I should unregister and register again.
Sadly, there are some regressions in v1.6.0 regarding the internal data structure and hotfixes are prepared as fast as it is possible.
shulamy Wrote:
i installed version 1.6.0 by editing the PKGBUILD
but the buttons are rendered as colored rectangles without text
i think i saw somthing about rendering problem but i don't find it now
is there a solution?
ezik
I assume, you are using Axolotl on Arch/Manjaro. As written in the previous post, there are some internal bugs to be fixed and the devs are on it. I will try to reproduce your issue with one of the latest Arch/Manjaro images.
Fingers crossed...
wget https://github.com/nanu-c/axolotl/releas..._arm64.deb && sudo apt install ./axolotl_1.6.0-1_arm64.deb
.........for some reason link does not work: error404, file not found?
Hello there,
sadly, I cannot recommend to use Axolotl at the moment. There are too many bugs and regressions to be fixed... The team is working their best, but it'll take some more time to make the app usable again.
Sorry for that...
It's a bit hard to type with fingers crossed, but I'll keep on...
(11-01-2022, 04:02 PM)arno_nuehm Wrote: sadly, I cannot recommend to use Axolotl at the moment. There are too many bugs and regressions to be fixed... The team is working their best, but it'll take some more time to make the app usable again.
Strange, I missed one message (image) the last days (AFAIK), but otherwise it seems to work still OK here (use axolotl every day, chatting with multiple different persons). Huh
BTW thanks for your work on Axolotl! Smile
  Mobian MMS/SMS text problem bcnaz 16 39,285 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,773 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 68,792 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 73,609 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,403 06-29-2025, 12:38 PM
Last Post: Hiraghm
  VoIP account on mobian dialer j_s 0 3,074 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,251 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,002 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,701 04-29-2025, 02:10 PM
Last Post: mdk
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 7,928 02-20-2025, 02:47 PM
Last Post: puffchumpy
