I just bought an pinephone and I am still learning. I recently flash mobia with full disk encryption. While updating the system using "apt full-upgrade" the system screen turn black. After line the whole day I restart the phone and I endup with no graphic. mobian login from console.
Pinephone lost graphic during mobian system upgrade
02-28-2023, 05:47 AM
(10-18-2022, 12:55 AM)cmpin Wrote: I just bought an pinephone and I am still learning. I recently flash mobia with full disk encryption. While updating the system using "apt full-upgrade" the system screen turn black. After line the whole day I restart the phone and I endup with no graphic. mobian login from console. Do you get the decypt password question before black screen?
02-28-2023, 12:40 PM
Is it the same problem than mine?
https://forum.pine64.org/showthread.php?tid=17899
02-28-2023, 03:11 PM
(02-28-2023, 12:40 PM)anonymous Wrote: Is it the same problem than mine? Mine new install does the same as yours. I had to reinstall last year due to upgrade stopping the system even booting. Just got red led flash and haptic for 5sec and then it turned off.
03-01-2023, 04:45 PM
Have you tried to reinstall, disable greetd and re-enable phosh before upgrading like I did?
| Mobian image for the PinePhone | Korfou | 2 | 637 |
04-27-2026, 09:57 AM Last Post: Korfou |
| bookworm vs trixie discussion for mobian in pinephone regular. | zetabeta | 80 | 57,162 |
12-24-2025, 12:11 AM Last Post: Kevin Kofler |
| cryptocurrency on mobian/pinephone | biketool | 35 | 67,372 |
10-08-2025, 06:21 AM Last Post: biketool |
| Mobian MMS/SMS text problem | bcnaz | 16 | 33,282 |
09-15-2025, 02:42 AM Last Post: georgegohl888 |
| XLibre for Mobian | Hiraghm | 0 | 2,708 |
06-29-2025, 12:38 PM Last Post: Hiraghm |
| Axolotl on PinePhone / Mobian | arno_nuehm | 223 | 315,779 |
06-25-2025, 01:19 PM Last Post: anonymous |
| VoIP account on mobian dialer | j_s | 0 | 2,425 |
06-15-2025, 04:19 PM Last Post: j_s |
| Mobian Pinephone Notification LED | biketool | 2 | 3,270 |
06-07-2025, 03:19 PM Last Post: KC9UDX |
| Vivaldi Web browser nearly native for Mobian | biketool | 3 | 3,877 |
05-06-2025, 02:19 AM Last Post: biketool |
| mobian calamares fail | merom | 2 | 3,713 |
04-29-2025, 02:10 PM Last Post: mdk |
