Evolution no longer runs on Arch Phosh.
Has anyone else noticed that Evolution can no longer operate on Arch Phosh? I get an error message "can not pars file" or something to that effect. Regardless of even reflashing thew device the error and message are the same. In Calendar none of my calendars can be accessed. They appear for example 2022 but I can't activate it. I have noticed the build number is 3.44.4 however on my computer (Fedora 36) it states 3.44.4-2 and I wonder if there is a significant difference. No big deal for me as I use Postmarket Plasma with no such issue.
Can't help but notice that Phosh seems to be experiencing some interesting problems.
TESTED: Arch Plasma, Arch Phosh , Manjaro Phosh, Manjaro Plasma
Fedora, Mobian, Postmarket Plasma, Postmarket Phosh, Kali, SXMO.
I don't use Evolution, apart from installing it to use calendars with Radicale on my server.
I just tested setting and pulling events with the Calendar app on Phosh and all is working.
p.s. I should mention Evolution runs, just the UI is so tiny I didn't try doing anything with it!
Arch Phosh (PP); firmware: 0.7.1; ADSP: 003
(10-17-2022, 04:06 AM)cone99 Wrote: I don't use Evolution, apart from installing it to use calendars with Radicale on my server.
Thanks for the response. I reflashed the device recently after the problem simply started after an update.
Never had this problem before at all. After checking into things decided to reflash it and used different options.
Still the same problem flashed it again normally answering yes to all changes - same problem.
As earlier stated I use plasma as well where this problem does not occur (same version) so for now
I will completely drop phosh until problem sorted out whatever that problem is.
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 3 10,348 01-09-2025, 05:02 AM
  LibreOffice usable with Arch Linux on the Pinephone? Peter Gamma 2 4,282 07-28-2024, 05:12 AM
Last Post: Peter Gamma
  stuck between phosh and plasma aular 0 2,574 02-27-2024, 05:55 PM
Last Post: aular
  Updating Arch Linux _radv_ 8 9,713 02-20-2024, 09:35 AM
Last Post: _radv_
  How to install arch with FDE user641 3 6,074 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 9,287 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 9,542 10-06-2023, 09:36 AM
Last Post: luppivega
  Arch with FDE user641 1 4,065 07-29-2023, 08:27 AM
Last Post: alpineduck
  No keyboard on Arch Plasma when entering password on document Chief 0 3,405 12-03-2022, 08:35 PM
Last Post: Chief
  Curious About Arch Ferriah 2 5,597 11-07-2022, 04:38 PM
Last Post: Ferriah
