No sound
Exclamation
Hello
I've just lost sound support. When I lost it two days ago, a reboot was enough to get it back but today, it's over. Any suggestion?
This workaround seems to work:
systemctl --user stop pulseaudio systemctl --user start pulseaudio
Enjoy Smile
(10-07-2022, 10:25 AM)anonymous Wrote: Hello
Enjoy Smile
with a sudo reboot same problem.
with systemctl --user restart pipewire-pulse
and the reboot menu at the top right of the display it's good
Enjoy Smile
with the reboot menu at the top right of the display it's good
Biktorgj's firmware? Did you edit this file bellow?
/usr/share/alsa/ucm2/PinePhone/VoiceCall.conf
Enjoy Smile
yes BF but if I change with 90% same problem
Enjoy Smile
It happened to me on arch a few days ago, and yesterday with a normal call I could not hear the other person, and the person could not hear me. There's something broken with the sound.
Enjoy Smile
Yes my suggestion is a temporary workaround. When you reboot, you have to reapply it. I'll try your suggestion.
P.S: Your suggestion doesn't seem to help, I still have to restart Pulseaudio to make it work.
I have the same problem since a few days. Sad
Interesting: When I reboot my PinePhone audio devices are missing, volume control not working - Every time! When I check pulseaudio status via:
systemctl --user status pulseaudio
...then pulseaudio is not running, it's "loaded" but "inactive".
Then I have to:
...and pulseaudio is running, audio device is found, volume control works, everything seems to be fine (how long? Don't know yet).
I installed available pulseaudio updates yesterday via apt update, but the problem persists. Sad
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
It is perhaps worth mentioning that installing PipeWire as a drop-in replacement for Pulseaudio, according to the Debian instructions, works on Mobian as well. I immediately did this on my Mobian install in order to get high-fidelity Bluetooth audio, and I have had no problems with sound since, even with all the recent Mobian updates.
(10-17-2022, 03:01 AM)LibrePhoneUser Wrote: It is perhaps worth mentioning that installing PipeWire as a drop-in replacement for Pulseaudio, according to the Debian instructions, works on Mobian as well. I immediately did this on my Mobian install in order to get high-fidelity Bluetooth audio, and I have had no problems with sound since, even with all the recent Mobian updates.
But what exactly did you do?
Here they also talk about pipewire:
https://fosstodon.org/@mobian/109109524888172541
But it's sounds like "No problem, it just works!"...  Huh which isn't the case on my phone (and pulseaudio is still here).
  Sound : notifications freelectro 6 8,577 06-07-2023, 01:03 AM
Last Post: freelectro
  My sound went away with calls... Not sure what happened. How can i fix it? usourypg3i 4 6,711 02-18-2022, 08:54 AM
Last Post: battlegarden
  Lost all sound Dinosaur1946 0 2,967 01-27-2022, 07:34 PM
Last Post: Dinosaur1946
  Sound design for Mobian S.E.B 4 7,083 12-27-2021, 05:40 AM
Last Post: Anna
Bug Sound defaults to Headset User 18618 10 17,523 10-21-2020, 06:06 PM
Last Post: ThrillGates
  No Sound After Reboots LMalilil 1 4,854 09-23-2020, 06:14 AM
Last Post: bobblestiltskin
  earpiece sound setting Gobelin 3 6,414 08-13-2020, 01:46 PM
Last Post: Gobelin
