No sms receival on Arch Phosh Pinephone
I was fine up until a few days ago until I noticed that I wasn't receiving any sms messages even though I could download and upload using my sim card data.
I'm using the default phosh messaging applications and haven't really altered mobile connections in any way that could alter sms performance that I haven't already tried turning on/off in attempt of getting sms to work again.
Is this a problem with the messaging application, mmcli, lower level modem software, the physical modem, my service provider, or something else?
I can provide further information - this is all that seems immediately relevant after searching through other threads about similar issues.
(10-04-2022, 10:15 PM)pineuser0 Wrote: I was fine up until a few days ago until I noticed that I wasn't receiving any sms messages even though I could download and upload using my sim card data.
Check your modem to see if it is "Clogged". Every once in a while my modem gets backed up.
Here are the commands I use:
List all the messages in the modem (this will give you a number use it in place of the XX)
mmcli -m any --messaging-list-sms
Delete message in the modem
sudo mmcli -m any --messaging-delete-sms=XX
This used to restart the modem (you should not need this)
sudo systemctl restart eg25-manager.service
It's possible your modem is full (see this report) but mmcli commands won't do anything about it.  You'll need to use minicom or picocom to send AT+CPMS? to the modem at /dev/ttyUSB2. A response like
+CPMS: "ME",2,99,"MT",2,99,"MT",2,99
means there are 2 messages out of a maximum of 99 in the modem. If the modem is full, you can purge it with AT+CMGD=,2
If it's not full then the problem lies elsewhere.
  Pinephone visibly losing power while plugged in Hiraghm 10 9,532 10-14-2026, 04:20 PM
Last Post: Flymoon
  Pinephone software Csanderson0313 3 1,938 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 88,090 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 26,561 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 8,905 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,754 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,341 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 3,011 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,370 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,795 10-21-2025, 12:12 PM
Last Post: Richy_T
