phone and plasma
with arch plasma, if the phone rings and the pinephone screen is on standby, I have to enter the phone’s pin code (not the sim card), and often it’s too late to take the call. What needs to be changed so I can take the call without giving the code as with phosh?
(10-02-2022, 03:44 PM)oihantto64 Wrote: with arch plasma, if the phone rings and the pinephone screen is on standby, I have to enter the phone’s pin code (not the sim card), and often it’s too late to take the call. What needs to be changed so I can take the call without giving the code as with phosh?
Chances are you have solved this by now but I have read in the forums here somewhere that editing a file so the modem doesn't sleep is a potential solution. However the battery drain is supposed to be greater.
TESTED: Arch Plasma, Arch Phosh , Manjaro Phosh, Manjaro Plasma
Fedora, Mobian, Postmarket Plasma, Postmarket Phosh, Kali, SXMO.
In my opinion, the problem comes rather from the need to type the password to answer the call, with phosh it is enough to type on the notification to open the phone, with plasma the time to type the password and the phone is answered
OK I see what you are getting at ... I haven't tried Plasma for calls but in Phosh Arch a graphic appears to answer call and pin / password aren't required. The phone stays locked. That had been my experience with calls.
  Pinephone with KDE Plasma stuck at K logo after update Daniello 0 2,079 06-20-2024, 01:52 AM
Last Post: Daniello
  stuck between phosh and plasma aular 0 2,337 02-27-2024, 05:55 PM
Last Post: aular
  Phone calls with no sound user641 14 19,341 03-12-2023, 11:43 AM
Last Post: alpineduck
  No keyboard on Arch Plasma when entering password on document Chief 0 3,179 12-03-2022, 08:35 PM
Last Post: Chief
  Latest version Arch Plasma looks good. Chief 5 7,086 10-23-2022, 01:53 PM
Last Post: Chief
  Phone no longer works at all AndyM 2 4,003 10-19-2022, 12:08 AM
Last Post: AndyM
  Incoming calls only vibrate, phone is not ringing lacriz 4 7,215 05-31-2022, 11:40 PM
Last Post: hannescam
  archplasma: phone et discover broken? oihantto64 3 5,542 05-14-2022, 03:38 PM
Last Post: oihantto64
  Last update bricked my pine phone :( lacriz 6 9,323 01-25-2022, 07:52 AM
Last Post: kqlnut
  Emulation on Pinephone UBPorts CE Running Arch Linux ARM Plasma Mobile horme7 0 3,325 12-12-2021, 10:29 PM
Last Post: horme7
