pinephone-support package not upgradable on Mobian
Hi everyone,
I've been casually using my PinePhone Mobian community edition for the past year and a half or so and love the progress that's being made on mobile Linux.
Yesterday I've installed some updates but I've noticed a package got held back, specifically the pinephone-support package.
Trying to apt install this single package gives me a warning that it can't be installed because "the following packages have unmet dependencies: pinephone-support: Depends: firmware-realtek-rtl8723cs-bt but it is not installable, unable to correct problems, you have held broken packages.".
I never ran into this before (plus the updates also uninstalled my gnome-software store + gnome-software-flatpak-plugin and settings application) and am kind of at a loss how to solve it since the package can't be found or upgraded. It seems kind of essential?
Did anyone else run into a comparable situation?
Thanks in advance!
yes I have ran into this problem, not sure if mobian support has gone belly up, last weekly build is 2022-08-21. I have been surviving with apt update, apt upgrade, apt dist-upgrade. There always seems to be some packages left behind, don't do apt auto-remove those packages are important. Had to go back to a weekly build to get the packages back.
(09-18-2022, 05:42 PM)AnAbolitionist Wrote: There always seems to be some packages left behind, don't do apt auto-remove those packages are important.
Just a question: What packages do you mean exactly? Huh
I do auto-remove regulary since I use Mobian, and it never caused problems (I did it NOT during the dependency problems which removed settings-app of course, but when my Mobian was "OK" before auto-remove -> It was also "OK" afterwards).
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
My concern was as you stated, when it doesn't upgrade cleanly, don't auto-remove it wipes out useful applications off the desktop.
(09-23-2022, 07:09 PM)AnAbolitionist Wrote: My concern was as you stated, when it doesn't upgrade cleanly, don't auto-remove it wipes out useful applications off the desktop.
OK, then I just misundestood. Cool
Thanks for clarification!
In case someone finds this thread, the package pinephone-support seems to have been replaced by sunxi-support in Mobian trixie (maybe that is also why the package was held back):
https://forum.pine64.org/showthread.php?...#pid126107
  Pinephone visibly losing power while plugged in Hiraghm 8 5,694 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
Exclamation No wIfI after Mobian update crakabeats 5 6,190 02-28-2026, 04:18 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 595 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 3,581 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 1,035 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 860 11-18-2025, 03:07 PM
  What is wrong with the Mobian signature key? Mahgue 0 705 11-08-2025, 05:13 AM
Last Post: Mahgue
  Pinephone boot. Richy_T 8 5,454 10-21-2025, 12:12 PM
Last Post: Richy_T
  How can I record video on a Pinephone? kk22 22 18,186 10-08-2025, 01:29 PM
  Does PinePhone support long-term battery health optimization? roseblack 5 2,088 10-06-2025, 09:05 PM
