low disk space on file system root revisited
I've flashed Mobian to the emmc and ran into the "low disk space on file system root"- issue. I already have removed unnecessary software, emptied tradh etc.......
I know this is still or has been a question discussed on this forum.
But there seem to be differentt ways of a solution.
Which one would you recommend?
Or is it depending of the chosen image?
(09-21-2022, 05:48 AM)benedikt55 Wrote: I've flashed Mobian to the emmc and ran into the "low disk space on file system root"- issue. I already have removed unnecessary software, emptied tradh etc.......
most likely, automatic resize did not work. i had this problem in recent weeks.
i hope you have ext4 fs and linux knowledge.
https://wiki.mobian.org/doku.php?id=trou...-pinephone
tried it, till an "........overlapping partitions" issue was arising..........what to do?
  Full disk encryption with calamares: beware of last testing upgrade! mdk 3 6,004 02-21-2025, 07:25 AM
Last Post: dragonhospital
  Short Guide to Using OpenVPN client GUI and .ovpn config file on PP biketool 0 6,758 12-16-2024, 02:07 PM
  How to use an NVMe disk as rootfs Smaking 3 3,566 11-29-2024, 06:51 AM
Last Post: walter1950
  boot gets stuck shortly after disk decryption vortex 9 12,655 09-11-2024, 05:40 AM
Last Post: normangraves
  Errors when start the system kubussz 2 3,941 11-21-2023, 11:07 AM
Last Post: kubussz
  System won't suspend due to suspention notification user641 6 8,766 09-24-2023, 05:47 AM
Last Post: user641
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 7,146 03-01-2023, 04:45 PM
Last Post: anonymous
  Bluetooth audio revisited 3x5co 1 3,635 01-10-2023, 05:51 PM
  German Emergency Alarm System Test arno_nuehm 4 6,652 12-11-2022, 01:44 PM
Last Post: traut
  Low Disk Space on Filesystem root ichbins 9 12,708 08-28-2022, 10:52 AM
Last Post: Eugo
