(ARCHIVED) Ubuntu Xenial Image (BSP Kernel)
Okay - will do. Thanks @longsleep. I just installed the image from this thread and updated it. As you noted, it shows the same behavior.
@benpope81 - I was probably a bit defensive. Sorry about that. Moar coffee.
(06-01-2016, 11:16 AM)jdt Wrote: @benpope81 - I was probably a bit defensive. Sorry about that. Moar coffee.
No worries, internet, etc.
I just enabled iSCSI as module (see https://github.com/longsleep/linux-pine6...930310e560) - will be in the next release.
Awesome - thanks. I was just tracking that down and saw the "updated 1 minute ago". Smile
Also hoping to get openvswitch working:
ubuntu@pine64:~$ sudo ovs-vsctl add-br internal
ovs-vsctl: Error detected while setting up 'internal'. See ovs-vswitchd log for details.
ubuntu@pine64:~$ cat /var/log/openvswitch/ovs-vswitchd.log
2016-06-01T17:30:33.307Z|00005|bridge|INFO|ovs-vswitchd (Open vSwitch) 2.5.0
2016-06-01T17:31:23.407Z|00006|memory|INFO|5848 kB peak resident set size after 50.1 seconds
2016-06-01T17:31:27.141Z|00007|dpif_netlink|ERR|Generic Netlink family 'ovs_datapath' does not exist. The Open vSwitch kernel module is probably not loaded.
ubuntu@pine64:~$ modprobe ovs_datapath
modprobe: FATAL: Module ovs_datapath not found in directory /lib/modules/3.10.101-4-pine64-longsleep
ubuntu@pine64:~$
(06-01-2016, 11:26 AM)longsleep Wrote: I just enabled iSCSI as module (see https://github.com/longsleep/linux-pine6...930310e560) - will be in the next release.
You know you rock.
@tllim, why doesn't tapatalk allow me "+1". I mean seriously, delegate, dude. How is everybodies problem, yours?
This is my problem; I want "like", "+1", whatever. Fix it now or I'll sue you for something I haven't yet decided upon but my lawyers will find.
Fingers crossed that this is the right module configuration flag and location to enable openvswitch: https://github.com/longsleep/linux-pine64/pull/20
Yeah almost. The configuration is created with the savedefconfig target and thus has specific sorting. Anyhow, i enabled that module as well and will include it with the next release.
I've installed this build, resized the filesystem, updated, upgraded, and installed the desktop (all through the serial console) but I can't get any HDMI output. Have tried 3 different monitors, 2 of which were 1920 monitors, tried 2 different HDMI cables, nothing.
The monitors obviously know something is there, it's just a black screen.
In the boot log I get this message, which is worrying:
[FAILED] Failed to start Load Kernel Modules
Could this be my issue? Also failed to set console keymap, but that doesn't sound nearly as serious.
Pine64 1GB with a 64GB class 10 Sandisk SD card (which obviously is good because Ubuntu is running fine).
U-Boot 2014.07-4-pine64-longsleep
Ubuntu 16.04 LTS (GNU/Linux 3.10.65-7-pine64-longsleep aarch64)
Any tips much appreciated...
Longsleep,
I prefer this minimalist approach. It keeps the quick installation process less cluttered and more educational. Stay command line or add the desktop of your choice. I used to do the roughly same with Unix builds on older hardware. Deja vu! (-:
Also, the contents of /usr/local/sbin were very thought out and very helpful. Thank you.
I have heard that some think that something is wrong with my images as they are so small. Properly compressed and not compromise cluttered is the reason.
@3lliot + something seems wrong with your installation and the kernel you post is not the current one. Try updating it.
  Ubuntu server 20.04 request phi0x 2 10,849 12-30-2020, 08:02 PM
Last Post: phi0x
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 27,219 08-30-2020, 10:35 AM
Last Post: jrronimo
  Kickstarter P64 with LCD, working image? MostHated 1 7,773 01-04-2020, 10:32 AM
Last Post: igorp
  USB Wireless Drivers with Longsleep Linux Kernel jacobscarter 15 40,615 03-06-2019, 02:26 PM
  Allwinner A64 RTC bug fix on bionic image? tkaivola 1 8,316 02-01-2019, 05:09 AM
  SPI on ubuntu IlyaM 4 14,426 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 14,074 05-18-2018, 03:33 PM
Last Post: Luke
  How can I get a wireless dongle working on Xenial Desktop latest build Rocklobster 1 6,719 04-16-2018, 03:09 PM
Last Post: Rocklobster
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 17,293 02-01-2018, 09:45 AM
Last Post: Partymack711
  PPTP doesnt work with ubuntu escovedo 2 13,375 08-23-2017, 09:28 AM
Last Post: gilbertotcc
