Connection to WiFi with OWE
Hello!
Just got a PineBook Pro on Manjaro and trying to connect it to WiFi network with OWE, but no luck. To networks without it connection is fine.
In logs I do see this:
NetworkManager[495]: <info>  [1661936785.2866] policy: auto-activating connection 'WIFI_OWE' (6df297b9-b9c7-4746-a934-725a10786425) NetworkManager[495]: <info>  [1661936785.2900] device (wlan0): Activation: starting connection 'WIFI_OWE' (6df297b9-b9c7-4746-a934-725a10786425) NetworkManager[495]: <info>  [1661936785.2906] device (wlan0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') NetworkManager[495]: <info>  [1661936785.2922] manager: NetworkManager state is now CONNECTING NetworkManager[495]: <info>  [1661936785.2945] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') NetworkManager[495]: <info>  [1661936785.2963] device (wlan0): Activation: (wifi) connection 'WIFI_OWE' has security, and secrets exist.  No new secrets needed. NetworkManager[495]: <info>  [1661936785.2965] Config: added 'ssid' value 'WIFI_OWE' NetworkManager[495]: <info>  [1661936785.2965] Config: added 'scan_ssid' value '1' NetworkManager[495]: <info>  [1661936785.2966] Config: added 'bgscan' value 'simple:30:-70:86400' NetworkManager[495]: <info>  [1661936785.2966] Config: added 'key_mgmt' value 'OWE' NetworkManager[495]: <info>  [1661936785.2967] Config: added 'ieee80211w' value '2' wpa_supplicant[528]: wlan0: Trying to associate with SSID 'WIFI_OWE' wpa_supplicant[528]: wlan0: Association request to the driver failed kernel: ieee80211 phy6: brcmf_set_key_mgmt: invalid akm suite (1027090) kernel: ieee80211 phy6: brcmf_cfg80211_connect: wl_set_key_mgmt failed (-22)
Any hints how it could be fixed?
Thanks!
Just to add,
`nmcli con modify WIFI_OWE 802-11-wireless-security.key-mgmt owe`
did not helped.
What is the correct way to verify I'm using latest WiFi driver? Or any way to use some alternative driver?
  Kernel Not Detecting Wifi tallfrye 10 8,666 01-01-2024, 06:57 AM
  Is there a way to turn off Wifi completely? jirow 10 18,840 06-20-2022, 05:53 AM
Last Post: Kaythe
  RTL8811AU usb wifi for pbpro vlut 0 3,228 12-02-2021, 05:23 AM
Last Post: vlut
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 5,779 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  Wifi disconnecting after few minutes hellojack 0 3,098 09-16-2021, 02:50 AM
Last Post: hellojack
  Fix your Pinebook Pro speaker connection KC9UDX 12 22,044 07-08-2021, 02:10 AM
  Advice on increasing WIFI range stozi 2 7,303 03-29-2021, 06:57 AM
Last Post: barray
  Curious about problem with PBP Wifi kendew 3 8,511 01-14-2021, 11:16 AM
Last Post: clover
  Privacy switches - cutting power to wifi card as400 1 5,316 08-10-2020, 09:48 AM
Last Post: belfastraven
  Soldering internal Wifi/Bluetooth antenna petet0n76 1 6,246 06-20-2020, 12:01 PM
